Speed issues on Hardware
JetSetIlly
Quote from: Andrew Davie on 12 Jul 2026, 03:59 AM
Quote from: JetSetIlly on 11 Jul 2026, 04:43 AMA good thing to add to these test binaries would be debugging information about the state of the MAMCR register
The attached version displays "MAM n", where n is the contents of that register.
Excellent. I'll be interested to see what it says when run on hardware. It probably says 2, but it says 1, then that would answer a lot of questions
@jetsetilly.bsky.social
SpiceWare
Picture is unstable, shows MAM 2.
Quote from: SpiceWare on 12 Jul 2026, 06:13 AMPicture is unstable, shows MAM 2.
TY. OK...
I've rewritten the game kernel. This version has a conservative 50K cycles budget for OS/VB.
So, new kernel.... fingers crossed.
SpiceWare
no bueno
#19
Quote from: SpiceWare on 13 Jul 2026, 02:00 AMno bueno
Dammit.
OK, once more into the breach; I do appreciate your assistance.
This one I put some timing diagnostics, found some overtimes in the emulator, fixed that (more a structural thing than a specific overtime), and increased the cycles to 100K. Honestly I currently have no idea what on earth is going on. I might, after this round, just retire worrying about it for a while.
I'm pretty confident the last effort has fixed the root cause.  There will be occasional overtimes still - I have to rework some code to make sure that everyting is "gated" properly in terms of time usage. But the fix I made will mostly work, pretty sure.
Taking bets... good odds offered!
Bizarre GCC bug found?
Vector to code through function pointer table --> 17.5K cycles
Direct call to code through if/else --> 2.5K cycles
Prior version kind of "masked" this problem.
This version nails it.
I'm still gobsmacked; this can't possibly be right.
Quote from: Andrew Davie on 13 Jul 2026, 07:41 AMI'm still gobsmacked; this can't possibly be right.
It's not. Stupid programmer error.
SpiceWare
Both recent builds still roll, video's of WenHopPlanetPluto_20260713@07_38_28_120K.bin
