Vox Probe 17 - Definitive Reference Recording
Previous topic - Next topic
**VoxProbe 17: one AtariVox+, one sitting, every sound three times**
Until now the emulation has been fitted against four recordings of every SpeakJet sound: an AtariVox+ and an original AtariVox, each recorded in two separate sessions. The idea was that four takes average out the chip's own randomness and tell us how close "close" can get.
Looking hard at the differences between those four takes has shown a problem. They don't only differ by the chip's randomness (its noise, its oscillators starting at random phases). They differ in ways that are consistent and real:
- **BE:** the voice bar before the release is about 7 ms longer in one recording session than the other.
- **OWIY:** the attack is three times slower on the original AtariVox than on the AtariVox+.
- **IY:** the AtariVox+ plays it about 10 ms longer than the original.
Averaging four takes like that gives a target that no real chip actually produces: half of one unit's IY length and half of the other's. And measuring "how close is close enough" from the spread between them sets the bar too loose, because the spread includes the differences between units and sessions, not just the chip's own variation.
**The fix is a cleaner reference**: every sound recorded three times, on one AtariVox, in one sitting, through the same recording path. Then:
- **The target is one real chip,** not an average of two units and two sessions.
- **The spread between the three takes is that chip's own randomness and nothing else,** so "as close as another recording of the same chip" becomes a precise, strict standard.
**The preferred unit is the AtariVox+.** It's already the reference for the emulation's levels and spectrum, so recording it again keeps everything measured against the same chip. The original AtariVox stays in use as a check. If we match the AtariVox+ but fall outside what the original does, that sound gets flagged, not fitted.
**What's on the ROM**
- **Running time:** about 4¾ minutes.
- **The title screen** reads VOXPROBE 17 B1.
- **A start reference:** a second and a half of silence, then a 1 kHz tone.
- **Then three rounds:** in each, all 72 speech sounds, then all 55 sound effects, each played on its own.
- **Before every sound,** a short marker: a moment of silence, a two-note tone, and another silence. The tone pair is one the SpeakJet never produces in its own sounds, so every item can be found and identified automatically in the recording.
**If you're recording it**, please use the AtariVox+, keep the same setup from start to finish, and don't stop partway. A single unbroken recording is what makes it work.
To clarify; one recording only is needed, from a genuine Atari 2600 unit, using the AtariVox+.
SpiceWare
Sorry, won't be able to get to this until next week.
My sister and her family are coming for the weekend. Usually she stays with me while her son & his family stay with my folks, but they decided to switch it around this time. He has 2 little ones so I've been baby proofing the house. The Atari and capture equipment has already been put away, it's setup on the floor and I didn't want any of it to get stepped on.
I would have held off on stashing the Atari except the last reply on probe 16 had:
Quote from: Andrew Davie on 18 Nov 2026, 07:38 AMNo further probe is planned: the recordings in hand settle what they can, and these stay open.
so I thought we were done.
Quote from: SpiceWare on 20 Nov 2026, 03:08 AMSorry, won't be able to get to this until next week.
All good. I've appreciated the fantastic assistance.
I thought it was the last too but Claude keeps throwing spanners in the works.
It's probably good enough now. I just get frustrated when it starts "transcribing" to make things work instead of trying to find the underlying "mechanisms".  If only someone would share the firmware, and all this would be moot.
JetSetIlly
Quote from: Andrew Davie on 20 Nov 2026, 03:13 AMIt's probably good enough now. I just get frustrated when it starts "transcribing" to make things work instead of trying to find the underlying "mechanisms".
The way it's going, I don't think it'll halt the process on its own. I don't think the underlying mechanisms can be found with this method.
I think the emulation is good enough.
https://github.com/JetSetIlly/Gopher2600
@JetSetIlly@mastodon.gamedev.place
@jetsetilly.bsky.social
Quote from: JetSetIlly on 20 Nov 2026, 09:01 AM
I'll soon put up the latest round of fixes, which are nonetheless significant, and then maybe call a halt to it all and get back to WenHop.
SpiceWare
The volume knob got bumped and moved. I think I got it back to where it was before (3.5). If there's any clipping let me know and I'll lower it and record another capture.
vox_probe17_2600_plus.aifc.zip 46 MB
TY for the recording.
# VoxProbe 17: results
## What it was
VoxProbe 17 (build 1, sha1 a9d6160a) played every one of the 127 sounds alone, three times round, each behind a marker tone. It was recorded on unit A (AtariVox+ on a 2600+) in one session on 2026-11-24. The point was to have one chip as the target, with a spread that is that chip's own. The probe is now frozen.
## The recording
- All 381 items were found and placed.
- The ROM pauses 2.6–3.8 s at each of its 31 chunk loads. These had to be handled in the placement.
- The recording path carries a 1 kHz line at −65 dB through the whole take, present before the chip plays anything. It was removed before scoring; the background then matches the earlier unit-A recording (vrnA).
## What it showed about the chip
- **Within one session the chip is very repeatable.** Level per sound agrees to 0.03 dB across the three rounds, length to 2 ms (medians).
- **Between sessions of the same unit, some sounds change.** The largest band difference in the whole-sound spectrum, median over 127 sounds:
  round against round (same session)          0.6 dB
  VoxProbe 17 against vrnA (unit A, earlier)  1.1 dB
  against unit B                              1.9 dB
  The path is the same: 221 A1 matches within 0.1 dB in every band. Yet effects that hold steady within a session move between sessions: 254 M2, 230 C0, 201 R1 and 204 R4 each differ by 2.5–3 dB. So part of the chip's variation is set at power-up and survives Reset.
- **A few sounds vary within a session.** 236 C6 starts its 1.5–4 kHz band at 3 ms in one round and 16 ms in the next.
- **Timing.** The markers measure each sound's start and the time to the next code, which no earlier recording could. Measured against the chip's IY and AX, all within ~5 ms across rounds:
  BE BO DE DO, PE PO TS KE KO CH    start with ours
  GE GO ED EB OB OD EG OG           start 12-24 ms after ours (the chip is silent first)
  TT TU                             start 34-40 ms before ours
  EK OK                             start 16-22 ms before ours
  VV ZZ ZH DH after a Reset         hand over 37-53 ms sooner than ours did
  M0                                hands over ~220 ms sooner
## What changed because of it
- **The measure.** X now scores against unit A alone: VoxProbe 17's three rounds plus vrnA, so the spread includes the power-up variation. Every sound reads further on this tighter target. All releases were rescored on it so the history compares like with like.
- **Engine.** A voiced fricative (VV ZZ ZH DH) after a pause and a Reset no longer gets a 40 ms noise lead-in; the chip voices it at once. Man Goes Down's DH, with no Reset before it, keeps the lead-in.
- **Refitting.** About 50 sounds were refitted to unit A. Every refit was locked in time to the chip and checked by picture, and allophones were also checked against the glides and phrases built from them. JH gained an onset in place of its hard burst.
- **Tried against the probe's timing and not kept**, because each made the score or the phrases worse:
  - a silent lead-in for the voiced stops
  - shorter closures for TT and EK
  - a shorter M0 tail
  - a longer GO closure: its end comes right, but one slowed phrase gets 7 % worse
  - a longer slowed bar
  - a from-silence onset for the fricatives, as a shared rule and as a per-sound field
## Result (0.5.8, committed, not tagged or pushed)
On the unit-A measure:
                 0.4.3   0.5.7   0.5.8
all 127 sounds   1.64    1.26    1.21
allophones       1.30    1.07    1.01
effects          2.10    1.50    1.46
51 sounds are closer than in 0.5.7, and none is further at any amount. Phrase items improved 236.3 → 234.3, with none worse. C/Go parity holds and the tables are ~7.3 KB of 8 KB.
Since that commit, B2 (1.594 → 1.546) and A7 (1.637 → 1.549) have been refitted and installed. They're not committed yet.
## Still open from the probe
- **179 GO** ends 5–7 ms before the chip.
- **187 SE, 188 SO, 178 GE** start differently from silence than in phrases, and no fix satisfied both.
- **173 OB, 180 EG, 181 OG** leave 18–28 ms more silence before the next code. Only this probe measures it.
- **217 A7's onset** has three faults: its click is ~3× too long, its main formant fades in over ~16 ms where the chip's is instant, and its 300–700 Hz band is 5–8 dB loud. The effect's own settings could fix these, but the fitter doesn't search them yet.
