Boulder Dash 2
Quote from: JetSetIlly on 30 Jan 2024, 04:45 AMBecause we're not running on a realtime OS there's no guarantee on when we receive the next frame for rendering. With flicker kernels this is a particular problem because it spoils the interlacing effect. We can increase the intensity of the phosphor effect but I don't feel this is a great solution in all cases.
TY for the great explanation!  "3" is working very well for me.
Had a bit of fun with the rage-quit skull.  The video shows a few iterations - it's now laughing at you, and at the very end a hint of a gold tooth :) I know it's not very productive. But, attention to detail right?
Bomberman94
Love it - much more atmospheric than a ,,static screen".
Aargh!  The eyes... the eyes!!
I re-used one of the frames from the title screen's firefly. It's pretty effective.
Here's a binary of the "rage quit" skull in action...
Having fun with the eyes.
At little extra ROM cost, I've revamped the "rage quit" sequence to incorporate complex masking and improved drawing. Essentially I can now animate the components. Like it or hate it, it's interesting at least. I need to improve the visuals of the jaw - doesn't quite look right to me. But I'm still happy with the results of this little bit of work.
I do a fair bit of "what-if?" stuff that never sees the light of day. This one was the idea of the rage quit skull resolvoing out of TV static. It looks OK, but I don't think I'll use it.  Maybe.  Tip: right-click on the video and select "loop" to watch it multiple times.
#38
Update. Static fading in and out. I darkened the underside of the bones to make them stand out more against the static.
markzilla1985
This looks great. What ROM size would BD2 be at? I'm guessing at least 64K and still enjoying the 1st one.  :)
Quote from: markzilla1985 on 26 Feb 2024, 05:22 PMThis looks great. What ROM size would BD2 be at? I'm guessing at least 64K and still enjoying the 1st one.  :)
< 32K
A solution to cave A/HARD.  It's quite tricky if you don't move those boulders out of the way to get the diamond. And you don't really have a lot of spare time - gotta keep moving!
Bomberman94
Cave A has now another layout?
Quote from: Bomberman94 on 29 Feb 2024, 03:59 AMCave A has now another layout?
Caves consist of a "base" + "extras".  All "cave A" variants share the same "base" - and from this version onwards that is basically two horizontal walls.  Each "extra" (a unique addition per level) can add on top of the base. In this "HARD" version, there's an extra chamber, and a rock generator.  The idea of "extra" + "base" is that I can get many more cave layouts cheaply. Sometimes the "extra" can be the addition of butterflies or fireflies. Sometimes it can be the addition of chambers. It gives me a lot more leeway to make caves slightly different on a level-by-level basis.
Bomberman94
Quote from: Andrew Davie on 29 Feb 2024, 10:47 AM
Understand - this will bring a lot more variation now! I like.
