Boulder Dash 2
Here's a new gameplay mechanic - "boulder run".  The idea here is just to get safely past a wall of falling boulders ASAP.  The video shows various difficulty levels. It's surprisingly hard to do.
#46
Well, I've dropped the above level/mechanic. Feedback was not great, and I'd rather spend the space on something else... like this!
I've added a short hint at the bottom of each status screen just under the mini-cave display.  It's supposed to give you a bit of an idea as to what to do on the level.  Interesting, I only have one font defined for the 3 sizes you see here. The top "CAVE" is the normal font display. 7 pixels wide.  The large number/letter are programatically doubled in x/y from that character set.  The proportional font giving the hint is halved in width from the original font (programatically).  It's all about saving ROM space. I quite like how it's turned out. Let's see if it ends up making the final version.
Edit: on reflection I should really make all of these hints in the form of 5-7-5 haikus
I can actually (automatically) generate a slightly narrower font, too - and if I'm going to use a haiku form, I need as many characters/line as possible. Currently averaging 4 per char, so 48 pixels/4 = 12 letters per line. But if I average 3, then I get 48/3 = 16 per line. Here's some examples of the narrower font. Given it's auto-generated, it's not so bad.  Mmh....
#48
I can/will refine the large-letter shapes to improve the auto-reduced ones. Here's a quick fixup for the W... showing both narrow and normal scaling
I don't think I'm going to be able to fit in a Haiku... sad.
Some attempts....
User
create a 5-7-5 haiku about unblocking a rockfall
ChatGPT
Blocked path, rocks entwined,
Hands and hearts move boulders free,
Unveiling new paths.
User
again
ChatGPT
Rocks cling, path obstructs,
Hands united, strength unlocked,
Flow resumes unblocked.
User
again
ChatGPT
Rocks fall, nature's call,
Together, we break the wall,
Paths clear, freedom sprawls.
User
again
ChatGPT
Rocks yield to our might,
Blocked paths clear, revealing light,
Unfurling new sight.
User
again
ChatGPT
Stuck in stone, dismay,
Hands unite to clear the way,
Freedom's light holds sway.
A minor update to the text wobble.  Sinusoidal magnitude now... because I can.
OK, I think I'm done with bug fixes and optimisations. It's ready. Now I just need approval to release a demo, and of course which screens/levels are included.  Here's a vide (with sound) of where it all stands.
#52
To assist with tweaking screens, I wrote/updated a little tool in Python to unpack the cave data and draw it using unicode characters. I can then place the output in my source code to help me see what's what.  It puts diamonds/boulders in exacty the right spots, too, so I can have it count the initial diamonds for me to configure how many you need for each level. It's pretty neat!
Having updated the diamond grab to include extra animations, I'd re-used the "extra life" staic characters (4 of).  In the process I modified those characters to make the dots in the static look more like small diamonds. That worked for the grab, but it screwed the "extra life" visuals.  I couldn't afford to add new characters because the set is chokka, but I came up with a neat bypass.
Essentially I have a small 2-character definition in RAM, which I fill with random 'dots' every frame.  As the screen is drawing each 'blank' character is drawn randomly FROM within this double-height random character. And, it works well enough.  That's what this video is showing - a constant "extra life" static display.
Bomberman94
If this then appears during the entire game and what happens if you get an extra life?
Quote from: Bomberman94 on 28 Mar 2024, 04:55 PMIf this then appears during the entire game and what happens if you get an extra life?
It *only* appears during an extra life. For testing, I turned it on permanently.
Bomberman94
In my opinion it looks even better than in the previous extra live animation! I'm curious to see this in ,,real gameplay on real CRT".
alex_79
Looks good!
How is it with "normal" (non interleaved) ChronoColour?
#58
Quote from: alex_79 on 28 Mar 2024, 08:15 PMLooks good!
Essentially identical, if not better
#59
Hard to screenshot effectively, an I don't want to put up a nearly duplicate video at this stage.  I'll be releasing a "release candidate" for the demo version to playtesters in a day or two.
iCC OFF
iCC ON
