Known Bugs
1. the swipe (star, circle) is not working properly.✅
alex_79
#1
The "20250717@01_46_09" build (BTW, it's always a bit odd/amusing that your binaries have the next-day date for most of us... ;D ) shows random/garbage gfx outside the walls✅ of each level in both Gopher and Stella if randomization is enabled ("Random State (on startup)" in Gopher VCS tab - "Randomize zero-page and extended RAM" in Stella developer options).
Also, both abort emulation and exit to the debugger with an error✅ if you set "Abort on Memory Fault" (Gopher) - "Strict ARM emulation" (Stella).
#2
Quote from: alex_79 on 17 Jul 2025, 06:10 AMThe "20250717@01_46_09" build (BTW, it's always a bit odd/amusing that your binaries have the next-day date for most of us... ;D ) shows random/garbage gfx outside the walls of each level in both Gopher and Stella if randomization is enabled ("Random State (on startup)" in Gopher VCS tab - "Randomize zero-page and extended RAM" in Stella developer options).
Also, both abort emulation and exit to the debugger with an error if you set "Abort on Memory Fault" (Gopher) - "Strict ARM emulation" (Stella).
That was an interesting one. TY.  The garbage-outside-walls is now fixed.
I haven't seen the memory fault one; will keep looking. Might have been the same bug.
The memory fault seen in earlier binaries; does not appear to be in the latest.
Latest binary updated in the download thread.
#3
The "suicide" button press time is way too short; currently a slightly-held button press will abort to the menu screen.✅ I'm going to insert an undo on that button so rather than release a new version with that delay extended right away, I'll just wait for that.
#4
It seems that NTSC/PAL/SECAM autodetect might be broken. Will investigage.
Fixed.
Funny and interesting SNAFU.  The autodetect is in the copyright screen code. Because I dumped the copyright, the easiest way was to only show it (black screen) for a couple of frames. But the autodetect code was set to wait 10 frames for precise calculation. So it never ran.  The copyright short-circuit, so to speak, ended everything too early.  So, now working.
