Instructions/Manual
OVERVIEW
This is a "couch-compliant" game: once powered on and you have (optionally) selected the screen display mode, you can sit back and play entirely using the joystick— no keyboard or extra input required. Gameplay, navigation, and control can be handled with the joystick.
PURPOSE
Sokoban is a timeless puzzle game where you guide a character through a grid-based warehouse, pushing boxes onto designated storage spots. You can push only one box at a time, and never pull boxes or pass through walls. These simple mechanics give rise to deeply challenging puzzles that reward careful planning, spatial reasoning, and methodical execution.
iCC/ChronoColour Screen Display Mode
The colour display technology (actually, there are two) is fundamentally a multiplexing of colours and pixels spatially and temporally to give the impression of more colours than are possible on a scanline. There are two basic methods.
1) iCC ("interleaved ChronoColour").  This is the default display mode, and the game always boots up in this mode. It gives a more solid looking colour at the expense of "shimmer". This 20Hz colour shimmer *should* be rendered almost imperceptible on a CRT TV provided you adjust the brightness and contrast accordingly. In emulators you can also do this; in Gopher I have my phosphor settings at "SLOW" and "LOW BLOOM".
2) just plain old ChronoColour. This is the original multicolour format, and does not shimmer - but displays colours more sparsely.
To toggle between the display methods, just toggle ANY of the console switches ("left difficulty" or "right difficulty" or "TV Colour") at ANY time.
The room colours are generated randomly. Mostly they look pretty good, but occasionally a garish/jolting colour scheme may come up. You can select a different colour for a room at any time by pressing the SELECT switch on the console.
ROOM SELECTION
The room selection screen allows you to choose any puzzle (or "room") to solve at any time. Rooms increase in difficulty and are selected from the 40,000-room database at sokoban-solver.com. Each room is identified by both an ordinal number and a unique ID matching that site.
A small in-game TV displays a live preview of the currently selected room, scaled to fit the screen.
    1. Use left/right on the joystick to browse rooms.
    2. Press the button to begin solving the selected room.
    3. After completing a room, the game will automatically advance to the next room.
To view the optimal solution for a room (number of pushes and total moves), press up/down on the joystick. This data is pulled from the same online database. You can also visit the website to watch a solution for a room. For this, you'll need the ID of the room.
Visit https://sokoban-solver.com/screens/<id>  -- replace <id> with the room ID as displayed in the game. The relevant room will be the first one shown in the page. Click on that, and you can then watch the solution for the room.
Once a room has been completed, its preview will appear in black and white with your statistics overlaid. To compare your performance with the optimal solution:
    1.    Select a completed room using left/right.
    2.    Hold up/down to view the optimal values.
You can replay any room at any time to improve your score.
GAMEPLAY
You move the player with the joystick. Pushing boxes is automatic, provided there is a space for a box to move to. When all the boxes are in position, the room will be complete.
Sometimes you can push a box to a location where it cannot be subsequently moved. If the box is not on a a target spot, then you cannot then complete that room. In this case, you will see a message indicating how many "stuck" boxes there are, and those stuck boxes will pulse in size.  The ONLY option when this happens (provided you want to complete the room!) is to revert the move using the UNDO system.
UNDO / TAKE-BACK SYSTEM
The game records the last 100 combined moves and pushes. You can undo any box-pushing move using the UNDO MODE:
    1. Enter UNDO mode: Hold the joystick button. After a short delay, the word "UNDO" will appear in the status bar, along with the total number of stored moves.
    2. If a box was pushed, an animated ring will appear around it—indicating it's ready to be undone.
    3. Press the button again to rewind the player's steps back to that move and reverse the box push.
This process repeats as long as there are recorded box pushes. The move counter reflects total player + box actions, which may not be directly helpful during undo navigation.
Exit UNDO mode by:
    1. Holding the button again for a short while, or
    2. Simply moving the player with the joystick.
EXIT ROOM
If you want to exit from a room, just hold down the joystick button until you return to the room selection screen.
ZOOM VIEWS
There are three zoom levels available: Normal, Mid, and Overview. Each provides a different view scale and is fully interactive.
    1. From Normal view, press and release the button to switch to Mid view.
    Press and release again to return to Normal.
    •    Double-click the button to switch to Overview.
    •    Press and release to return to Normal.
You can switch views at any time during play.
ROOM COMPLETION
A room is complete when all boxes are moved onto target spots. Upon completion, a stats screen will appear, showing your number of pushes and total moves.
Press the button to return to the room selection screen. The next room in sequence will be automatically displayed—press the button again to begin.
