Image Mockups/Feasibility Testing
Using the 8-colour iCC system, here are some graphical mockups.
I draw the cars in an 40x66 image, which is the "trixel" dimensions of the screen.
Then I scale the image to 320 x 192 to give approximate aspect ratio and look-and-feel.
These car mockups are designed to fit into iCC 10 pixel x 30 scanline character blocks. Each car takes 2x2 or 2x3 (or, flipped horizontally 2x2 or 3x2 characters.  Because a trixel is 1 PF pixel x 3 scanlines, the cars in a 2x2 character block are actually 10 pixels wide, 60 scanlines deep. The 2x3 is 10 pixels wide, 90 scanlines deep.
So far; first impressions; it's workable, but the large size of the cars and the odd pixel aspect may make design a bit tricky. I will have to use the multiple zoom levels, to make it playable. We'll be scrolling over the larger view of the cars shown here, and will have smaller representations in other zooms.
I do have the ability to change the engine's width and depth of characters.  For example, Boulder Dash was 4 wide x 24 deep.  WenHop, using the same engine was 5 wide x 27 deep. Engine can go up to 8 wide and arbitrary depth.  So the issue with the aspect ratio of the cars can be adjusted; keep the matrix of 2 x 3 (for example) characters, but instead of that being 10 pf pix x 30 trix (90 scanlines), we can have characters 4 x 30 and thus cars being 8 pf pix x 90 scanlines. At the cost of horizontal resolution of course. We shall see how things turn out. I need to do a few mockups showing these graphics or similar actually being drawn by the engine.
Here are some screenshots from Gopher displaying some sample graphics. I just replaced the Sokoban title screen with the mockup, so it's really just a visual test. It looks mostly OK to me. I had to find a size where I could have clearly recognisable cars, and keep the aspect ratios for the x and y roughly the same. In this iteration, the cars occupy 8-pixel-wide by 14 trixel deep cell positions. Thus, a vertical car shown here is 1 wide x 2 deep cells, which is 8 x 28 trixels.
The screenshots show a few different coloured cars, vertical and horizontal.
I have both the ChronoColour and the iCC versions for comparison.
Test with smaller car graphics...
Smaller again. This looks OK.
Bomberman94
I think chronocolor looks better - some kind of scanlines and ,,not so solid" areas.
#6
Some random colour selections.
Also, the original source graphics - dunno what that horizontal blob top line is but some of the other cars look OK to me. Fun to draw, but kinda hard to make look good.  The screenshots from Gopher are 32 pixels wide, as I'm hijacking the title screen display just for these mockups. Nonetheless, the sizing is *about* right for the cars, as we need a 6x6 grid for the cars to operate on. I'll use the other space for some sort of scoring counter.  In the brighter image showing 8 horizontal grid positions, that's just my source graphics and shows what 40 pixels wide PF can hold.
Quote from: Bomberman94 on 20 Aug 2025, 09:36 PMI think chronocolor looks better - some kind of scanlines and ,,not so solid" areas.
It doesn't look too bad, agreed. I'm going to leave it switchable so the player can choose either.
