Cars moving around grid/lot
In this update I have the cars moving around randomly into legal positions. The car on the right-side is the "sprite" which I'll use to give fine-movement of those cars when under manual control rather than random.
#1
I've now added the exit-condition check, and drive the trapped "solution car" offscreen when the exit row is clear. I've also done some work on car redrawing. Although many of them look like old-school racecars, that was not deliberate. The resolution is painfully low (typically horizontal = 9 x 10 trixels, vertical = 4 x 21 trixels) and it's quite tricky to get anything that looks anything at all like a car. So, these aren't that bad, considering.
