Dynamic brightness control
Hold SELECT (F1) and use the joystick UP or DOWN to adjust screen brightness.
It's useful to optimise the visuals of iCC and reduce flicker/shimmer.
Also quite unusual; I don't think it's been done before on the '2600.
Here's a video of it in action.  I'm just using SELECT+joystick to change brightness on-the-fly, via software -- so this isn't an emulator thing... it works on real hardware.
Bomberman94
Great idea - should be a standard feature (if not too much data consuming).
Quote from: Bomberman94 on 07 Sep 2025, 09:53 PMGreat idea - should be a standard feature (if not too much data consuming).
EXTREMELY cheap. Just a few bytes function call, and the function is very small.
I guess I just didn't think of it before.
#4
The latest version of this has some adjustments to behaviour, and control.
* behaviour - fade now fades completely to black, or to "bright"
Bright is effectively "washed out, no colour"; I can't make all "effective" colours white, because the colours we see are formed by a time-based combination of the three *actual* colours. If I set all the actual colours to white, the iCC system blends those 3 to give 8 'virtual colours' so to speak. Those being formed by the on/off use of the 3 colours.  Off being black, we thus have various combinations of white and black.  In other words, shades of grey.  So when you "turn the brightness right up" in this version, you see a kind of OK greyscale image. I could just limit it to the brightest of the actual colours rather than switching to white -- but for now I don't mind the effect as it is.
* control
As before it's SELECT(F1) + joystick UP or down. The brightness setting is persistent between the title screen/menu screen and the game puzzle screen.
I have brought back the "change the car palette" option, which used to be on a press of SELECT(F1). That would cycle randomly to new car palettes if you didn't like the one you had. When I used the SELECT for brightness control, I thought I wouldn't have the car palette change, but I changed my mind.
Instead, now you have to press and then release SELECT(F1) to change car palette.  Note, when you do change palette, the brightness is reset to the "normal" value, so you see the palette in original state.
I have also placed a brightness reset on the title/menu screen.
TL;DR
press/release SELECT to reset brightness control to default
in the game screen this will also change the car palette selection
hold SELECT and use up/down on the joystick to change brightness.'
Grab the binary from the latest downloads section.
#5
Images at highest brightness settings.
