A little bird told me...
Well, either tomorrow or Friday I expect to see something new - kinda dazzling and show-stopping - on ZeroPage Homebrew. Something developed by a homebrewer, of sorts, that will test Atari's commitment to open forums and community. Better watch the show, hadn't we!!
Thomas Jentzsch
Early show? I will be there!
JetSetIlly
Just seen the thumbnail advert. I was just thinking this weekend that someone should do something like this.
@jetsetilly.bsky.social
alex_79
Quote from: JetSetIlly on 13 Sep 2023, 05:00 AMJust seen the thumbnail advert. I was just thinking this weekend that someone should do something like this.
Ditto!
I've always been convinced that the only way to get this right was to have it developed by someone in the community.
And, in a sense, this is the perfect timing for announcing it.
JetSetIlly
Quote from: alex_79 on 13 Sep 2023, 05:06 AMAnd, in a sense, this is the perfect timing for announcing it.
It really is. If it's anywhere near completion then the reaction will be very interesting.
Adam
Adam
That's going to be amazing to see and Atari's response is going to give us a clear indication of what to expect from them.
JetSetIlly
The show was on way too late for me. Any news to report?
JetSetIlly
Is this Al_Nafuur's project that I've seen this morning on AA, or something else?
alex_79
Quote from: JetSetIlly on 13 Sep 2023, 05:14 PMThe show was on way too late for me. Any news to report?
Haven't seen it yet, either. I will do this evening.
Quote from: JetSetIlly on 13 Sep 2023, 05:56 PMIs this Al_Nafuur's project that I've seen this morning on AA, or something else?
I'm pretty sure it is.
Very exciting news. Previous discussion about the possibility to interface an emulator in real time with a cartridge suggested this was going to require a very powerful CPU (and a different emulator written for this purpose, runing on a real time OS). If it turns out that this can be achieved wiht affordable hardware it will be awesome. And it's great that this will be an open project, as it will benefit from the input and expertise from the community.
Using an emulator solves one of the big isues with an hardware recreation of the 2600: the inconsistent, out-of-spec and game dependent video output. The emulator can emulate the CRT behaviour and then output a steady on-spec HDMI video.
I hope that the same approach used for the catridge port can be used for the controller ports too. I think you'd need 15 more I/O for that (8 for SWCHA, 6 for INPT0/5 and one to enable the "dump" transistors for the paddles), and a few external components. Real time access to the pins would reduce the input lag, I guess, and the emulator wouldn't anymore need to emulate the various controllers and devices, but "just" read/write to the I/O bits directly. And just like the cartridge port, it would assure 100% compatibility with existing and future peripherals using the ports.
alex_79
Quote from: alex_79 on 13 Sep 2023, 06:58 PMAnd it's great that this will be an open project, as it will benefit from the input and expertise from the community.
Of course, the flip side is that once this will prove to be working, companies such as Atari will sell it for profit without acknowledge the work of the people who made it possible...
alex_79
I just watched the part of the show about this new device. Very interesting!
At the end of Al Nafuur's video with the "Pole Position" cart, you can see that he unplugs one wire from the breadboard (to power off the cart, if I understand correctly) and Stella immediately exits emulation and switches to the debugger with an "Invalid instruction" error. How cool is that?
For the FE cart, it would be worth trying with shorter cables between the RPi and the cart slot (or better yet, a pcb): my only cart of that type (a PAL "Space Shuttle") doesn't work when plugged into my cart dumper (a pass-through eprom cartridge which then plugs into the 2600), but requires me to hot-swap the carts and plug it directly in the console. Those few cm of extra wires between the cart and the cartridge port are enough to make the bankswitching fail. The same rom flashed in the Harmony cart in developer mode works fine also with the extender.
I'm looking forward to see how this project will evolve!
JetSetIlly
Quote from: alex_79 on 14 Sep 2023, 01:59 AMI'm looking forward to see how this project will evolve!
It's showing great promise. I think the OS on the PI is a big overhead.
killersquirel
Is there any updates on this console?
