Elements of the game
Per ChatGPT...
Lemmings (released 1991, originally by DMA Design) is a puzzle-strategy video game where the player must guide a stream of small creatures — the Lemmings — safely from an entrance to an exit. The game is built around giving the Lemmings limited, specific abilities to overcome hazards.
Core Premise
   •   Lemmings fall out of an entrance hatch one by one and walk in a straight line.
   •   They do not avoid danger by themselves: if they encounter a drop, a trap, or water/lava, they die; if they hit a wall, they turn around.
   •   The player's job is to assign special skills to certain Lemmings so enough of them reach the exit before time runs out.
Game Mechanics
1. The Lemmings Themselves
   •   Spawn continuously from the entrance at a set release rate (which can often be adjusted).
   •   They always walk left or right until acted upon.
   •   They are expendable: you usually only need to save a certain percentage to win.
2. Skills
The main mechanic is assigning one of eight possible skills (original game set) to an individual Lemming:
   1.   Climber – scales vertical walls.
   2.   Floater – uses a little parachute to survive long falls.
   3.   Bomber – self-destructs after a countdown, blasting terrain.
   4.   Blocker – stands still and forces other Lemmings to turn around.
   5.   Builder – builds a diagonal staircase of bricks, good for crossing gaps.
   6.   Basher – digs horizontally through walls.
   7.   Miner – digs diagonally downward.
   8.   Digger – digs straight down.
Each skill can only be assigned as many times as you have in your limited inventory for that level.
3. Terrain & Hazards
   •   Destructible terrain: can be dug, bashed, or mined through.
   •   Indestructible terrain: steel or bedrock areas immune to digging.
   •   Traps & hazards: water, lava, crushing traps, fire, etc. Instant death.
   •   Falls: if too high and not equipped with a Floater, Lemmings splat.
4. Player Controls
   •   Point-and-click interface: click on a Lemming to assign a skill.
   •   Adjust game speed and release rate.
   •   "Nuke" button destroys all Lemmings (useful if stuck).
5. Levels & Objectives
   •   Each level specifies:
   •   How many Lemmings will appear.
   •   How many must be saved to succeed.
   •   Which skills and how many uses of each are available.
   •   A time limit.
   •   Levels ramp up in difficulty, from simple introductions to complex puzzles requiring precise skill assignment and timing.
6. Victory Condition
   •   Save at least the required percentage of Lemmings before the timer runs out.
📌 In short: Lemmings is a puzzle game about resource management and timing — using a limited toolkit of skills to manipulate an otherwise mindless horde into navigating terrain safely.
