Gridlock Lumacode test - NTSC 7800digitizer (2600 mode)
crossbow
Tested and played a bit of Gridlock through my atari 7800 that is running the newest FW for the MARIAdigitizer and provides Lumacode output from the console. Here is a direct HDMI capture with no editing showing the game running in demo mode and looking awesome!
https://drive.google.com/file/d/1wXK6JvoGqvqH-AiVqsIz4t6rRIeH4gNg/view?usp=drive_link
Quote from: crossbow on 10 Oct 2025, 12:12 PMTested and played a bit of Gridlock through my atari 7800 that is running the newest FW for the MARIAdigitizer and provides Lumacode output from the console. Here is a direct HDMI capture with no editing showing the game running in demo mode and looking awesome!
Thanks for that. The video is only showing every 2 frames (i.e., 30 Hz) instead of the 60Hz required!
It should look MUCH better.
crossbow
I had everything set to capture at 60hz what I see on my TV and the preview window looked correct. The video stats say it is 60hz but you are right. The actual video or I should say the capture device appears to have issues with the interlacing is my guess. Strangely it doesn't seem to have this issue with the 7800 games I've recorded and they looked correct.
OBS did a slightly better job in some cases but there were still instances where it looked to only be recording half the frame. But yes, it looks much better in person.
Quote from: crossbow on 10 Oct 2025, 02:12 PMI had everything set to capture at 60hz what I see on my TV and the preview window looked correct. The video stats say it is 60hz but you are right. The actual video or I should say the capture device appears to have issues with the interlacing is my guess. Strangely it doesn't seem to have this issue with the 7800 games I've recorded and they looked correct.
Well, technically it's NOT interlaced (as a broadcast TV signal is). It's 60Hz non-interlaced, like nearly all '2600 games. Perhaps that's confusing the capture device.
