Porting Graphics / Level Editor
It's time to knuckle down and port some data.
I installed DOSBOX for MacOS, which is working OK, although grabbing the mouse foucus took me a while to get right. Really really weird to be running an old DOS/graphics application. This was the sort of thing I did in the late 80s.
Anyway, I found LEMEDIT3 and seperately I found an original Lemmings copy which had data files (some of) which could be loded by LEMEDIT3. And from those, I found this one level which looks nice enough to use as a first example of what I want to port.
So next step is finding documentation on the data file format and somehow porting it over.
First look at Lemmings File Format suggests that the tiles are of varying size, and can resize and rotate. That's not going to work for me, so I'm going to have to write a Python Level Tool. That tool will create and "draw" a level from the data set, and then re-pack it into 4x4 character matrices. This will take some time. Watch this space.
I've proceeded with an image->pCC conversion tool. It's very early days, and extremely buggy. But here's the first results.  The image here is an earlier version that I haven't mangled to help the tool get better colours; but it does give the general gist of the hill shapes and how it's converted those.
