Bit of thinkning about a new game
Just a glimmer of a game concept here. Thought I'd jot down some notes.
Initially "The Quiet Sea" but perhaps "Squarebergs" is a catchier name...
a grid of squares on a wrap-around "world" larger than the screen - so we have limitless wraparound scrolling
in all directions.
The world is populated with squares which have various attributes
* we have multiple colours (and even designs) available
* use the existing sprite system
* squares - let's say 4 wide (or maybe 5)
* player moves around from square to ADJACENT-ONLY square
* teleports?
* squares can be locked together into "islands"
* islands can move - until, at least, there is any sort of barrier (another island)
* enemy creatures move from square to square
* decouple islands
* destroy squares
* try to catch the player
* player goal is to form words (???) by arranging squares
* implying squares have letters on them. 5 wide would be required
* words are formed in any zigzag direction
* we can have multiple words
* kinda scrabble-like, but not just straight lines
* points scored for word formation
* require a dictioary?? or just have preset words to form << better
* use software-sprite draw, so we can move islands on 1PF pixel basis
* super smooth scrolling
* player can link squares (automatic when square/island being ridden connects to another)
* islands can spontaneously lose bits -maybe they're squarebergs
* what's the goal?
* well, form the words
* link squares to form pathways the player can travel to get to.... certain waypoints
* so the waypoints could be actual land-based islands with resources
* player can use a zoom-view somewhat like BD2 (double-click) - so we have a 40-square-wide world again
* or, the zoomed view only shows +/-20 and is itself scrollable
* perhaps with the islands, we're trying to reunite a larger picture, like a jigsaw
* move the tiles around - as we reunite pieces they lock
* or, we could have the goal of uniting islands of similar-colour squares
* the level being complete when there are single islands for each colour - no two islands the same colour. this would work.
* we could have different size squares, too.  The 4x4 and 2x2 and even 1x1.
* instead of juust stopping, islands could reverse direction or even move in arbitrary direcitions when collisions happen. Think of a giant asteroid field with various size islands (=asteroids) all moving around in various directions. In this scenario the player also controls island direction.
* control: perhaps each island has a "seed" square, and depending on where the player is related to this seed (central) square, then movement is applied through that centerline to the player square. That is, player has just forward and backward moves, applied to the whole island in the direction of the center square. So to steer, player needs to hop around various squares on the island and apply forward/backward.
* so we might need to "steer" squars or groups of squares toward other similar groups - we could have inertia for the large groups, so the bigger the island the slower it moves.
* goal could be to beat a timer.
* do we even need enemies?
Bomberman94
#1
Sounds interesting and after the first lines I instantly thought about RockNBolt:
https://youtu.be/it8Q-RP6D_M?si=6tlMfME9SLLRW9wv
I think the action of connecting squares together, right color AND forming words is a bit too much. I would stick to the action parts - forming an island, fleeing from enemies will be fine. For example: The player could form a given shape (of an island) in a specific color and defeat enemies within a time limit.
The main idea: forming/connecting blocks to solve something and enemies that follow is great! With good visual presentation and a cute character (little man with a hammer or so) it must be a hit.
Some more thoughts on the mechanics:
* "islands" are groups of square tiles of the same colour, in any arrangement
* the aim of each level is to connect all similar colours into island groupings
* there must (at the end) be only one island of each colour
* islands can move -- they continue movement in their last direction indefinitely (so, think icebergs)
* movement speed can be fast or slow -- any speed, really
* player can move islands
* to move an island, position on an edge square, hold fire, and push in the desired direction
* however, if the direction you push is towards a blank (relative to your square), your square will separate from the island, carrying you with it - this is how you transport around the world; riding a square
* effectively, to push an island in a given direction you must be on the opposite edge
* if you "bang into" another island, your island will join the island if the same colour
* however, if your movement speed is too great, you may fracture/break the island into pieces
* the game starts with many pieces, different colours, all moving around in straight lines
* islands which are unoccupied by you will NOT join to other islands/squares of the same colour.
* the more you push in a direction, the faster the island your on goes
* you cannot speed up and slow down and island from the same square; that's because you have to be on the edge of an island to push it, but if you push the joystick in the other direction, your square separates, as mentinoed above. So, to slow down an island you need to run to the leading edge and push back the other way
* so, if you're attempting to join two fairly sizeable island of the same colour, and your island is going too fast, you are likely to shatter one or both islands into individual squares going all in random directions
* you may have a power-up of some sort that allows you to lock individual squares together
* the world is wrap-around; think on the surface of a sphere
* islands become unstable in several ways
* as levels progress
* based on connectivity of squares - connected to 1 = very unstable; connected to 4 = very stable
* unstable islands break apart (gradually)
* player can lock squares together, and unlock
* locked squares are stable
* goal would be to surround the edge of your island with locked squares, so it doesn't break apart
* instability of 1 and 2-connected squares discourages long thin (1-wide) islands
* player can walk across islands - just use joystick as expected - but cannot walk onto water/space
* the act of moving in the water/space direction automatically separates the current square from any attached island, and you move around the ocean effectively floating on your mini-island-square
* if you bump into an island/square of a different colour at low enough speed, you walk onto the new island
* or perhaps when it's apparent, you simply jump and the island you were on slows down or stops
* start with only a few coloured squares and mini-islands to build - perhaps a limited size wrap-word
* on later levels more colours, more islands, more squares
* you may have "weapons/assists"
* a lock as mentioned previously, to join two squares together "peramanently". The island containing those squares can still move, so the lock is relative to the island/squares, not a global position lock
* an ice-pick or axe of some sort, to destroy a square permanetly
* perhaps 2P mode - competing.  You could build barriers (locked square sections) to prevent other player moving large islands in certain areas
Bomberman94
Very interesting - i think only ,,playing with the physics" or say riding an Island is fun. Does it have the feeling of a large ship, means you go to one side press button to steer in a direction and it slowly swims in that direction and than becomes faster? Thinking of the island graphics: are they only smooth edges or can you do a more natural appearance like frayed sides?
Maybe i'm too far away with my questions and you first try to determine the basic rules...
Quote from: Bomberman94 on 05 Jan 2026, 01:52 AMVery interesting - i think only ,,playing with the physics" or say riding an Island is fun. Does it have the feeling of a large ship, means you go to one side press button to steer in a direction and it slowly swims in that direction and than becomes faster? Thinking of the island graphics: are they only smooth edges or can you do a more natural appearance like frayed sides?
A real haphazard answer - all over the place - because this is just a late night (well, 2am) stream of thought as I go through the possibilities. Some inconsistencies here because I'm not putting any effort into proof-reading...
It feels like massive ship, yes. As you describe is basically correct, but see below I'm not sure yet on the controls. Mass depending on the size of the island, basically. You move small islands (e.g 1x1) very quickly, and larger ones much more slowly. As noted below I'm now thinking you might hold button down to move the island, and no button to move the player. Or not. I'm undecided.  If you're moving the island, your player stays in place and you accelerate the island with U/D/L/R.  Or, I still kind of like the push-only mechanism so you'd have to be VERY active running from one side of the island to the other to get into the right place to steer it; that might be frustrating. Still to work out how this is to be done might need some actual testing/playing to determine.
It's all to be very blocky - composed of only the squarebergs joined together. See image. So, no smooth edges, no features. Or maybe I can smooth - mentioned below. I want it to be pretty clear what parts you can break off - that is, where the squares are. To some degree this will be determined by the player position, because he will always be centered on a conceptual square centerpiont.  I could perhaps make the player square more obvious with a border around that square, or a different colour, or pattern. Note, that is relative to the island "reference frame", which may be offset from the other island refrence frames.  Maybe some cracks but still just very plain. Image shows a mockup just to give the idea. Squarebergs are just conglomerations of the flat squares upon which you can 'ride'.
Regarding the image
I've put numbers on the image to make it easier to describe.
We see a gazillion islands, many 1x1 drifting fairly quickly. They may auto-join (see below). he player will have to combine those together, by somehow getting onto the small ones and riding them to join others of the same colour. Need to think about the mechanics of how to get to an isolated square. Perhaps ride a square out to it, apply a lock and then ride the combined island back (might be yellow+green locked together at this stage), such that both are on an island edge. Unlock them (they stay in place) but now you can "attach" one to the island you're nearby, and "ride" the other to the island it needs to be on. Interesting mechanic. Qb had similar mechanics, in a way -- to get to an islolated cube you had to actually form a bridge by moving others, then move the extreme one to where you wanted, and use the bridge to return. Not exactly the same mechanism, but the similarity is I expect to have to use other squares to assist you to get to and 'retrieve' these isolated ones, and for moving between islands.
Anyway, to the numbering in the image... I've darkened an area roughly equivalent to a screen width/height (i.e., what you'd actually see) based on a 5-pf pixel wide square. Remember, we will have zooming like in BD so we can get broader views. But this is the large view.
And the numbers...
#1 -- if you push left or down, the square detaches from the island and you're riding it solo.
#2 -- is a solo 1-square-island. To get to it, youhave to ride another square to be adjacent, and then walk onto it. For example, if you start at location #1, you could detatch it, ride the pink square over to the #2, lock the two together and ride the green/pink conglomerate back to where #1 came from, dock #1 and then walk onto #2, then ride #2 to the green island to the left. Complex, but workable.
#3 same thing - detach #4, join with #3, ride the #4#3 island to join the large green island. Or, maybe #3 is slowly drifting and it auto-joins the larger green island when it comes nearby.
Another idea for getting #2... if you're standing at #1, walk up to the top of the pink island.If you're close enough, throw a "harpoon" over (recall the rope weapon I had in Wen Hop?) and pull the island towards you so it's close enough you can walk over to it from the pink island. They don't join but maybe they're kind of "sticky" for a bit. ANyway, walk over and you are now on #2 and able to move it.
I see the startup state with all of these individual 1x1 islands slowly drifing around the ocean. If they bump into each other, then maybe like-colours could auto-join and then move more slowly. We'd see accretion, in other words. That would be neat. I could have a sort of jiggle animation with particles flying off and suddenly you have a bigger island.  Leave the starting state long enough and you'd have a few larger islands there which would need to be broken up because they're all in the way of you joining like-colours into a single island.
I'm not putting too much effort into "locking down" gameplay/physics/control at this stage. Just want enough basic information to understand the systems that I need. I will, once that's done, start working on making the graphics look nice (perhaps softer edges after all), and the controls work.
Based on this mockup, I think i have to drop the "must be on an edge". Maybe. Instead, any square on an island will move the island, unless there's water right next to you in the direction you push - in which case the square detaches and you ride it. Still very unsure about this mechanic; testing will be the key.
I like the islands being a little like "soap bubbles" in that they sometimes spontaneously "reorganise". For example, the large pink island might tend towards being circular by those arms on the right drifting towards the island's "center of mass". All islands could do this -- just reorganise every now and then.
As mentioned earlier, I think, "stability" could be a part of the difficulty. Higher levels are less stable, and things dont' necessarily remain where you put them. Islands can disintegrate by slowly breaking apart, can be more "brittle" if they're hit by another island, etc.  The reorganisation can be rare (or common) at low levels, and the opposite in high levels.
Low reorganise makes things easy because you can build bridges if you want to connect two far-apart but same-colour islands which can't move towards each other because of a barrier (e.g., another island). But if reorganisation is common then you might not have enough time to build a stable bridge.
It's late - just ideas, but interesting.
