1st level design attempt
I re-enabled the "rope" weapon, which is as awesome as I remember.
I thought "How could I use this as a gameplay element".  And this is the result. You start up surrounded by rocks. The only thing to do, really, is use your "weapon" to destroy them to exit. And then you use your pick/hammer to setup a chain reaction in the geodoge, allowing you to collect the required dogecoin to open the exit door.
It all looks pretty awesome.
Partway through there's a 2nd level in there; currently not refined.  Just presenting that first level here in this video. This experimental 1st level is almost good enough to call "finished!"
Here's another.  In this one you have to get something like 30 doge.  You convert the geodoge to doge through a chain reaction where you just tap on them with your hammer. All well and good, but as soon as you do that, the Wyrms start eating the coin. So it's a race which you pretty much always lose.
So the trick here is to "lay pipe" to cut off the wyrms from accessing the doge.  In the video I try several ways to do that, sometimes failing sometimes succeeding.
Once you get all the required doge - the background flashes, and the door opens. Only the door is at the top where the wyrms are, behind the barrier. So you have to go up to the barrier, tap that with your hammer, and then you're able to access the door.
It's kinda cool.
Various screen-jumps because wyrm processing is expensive and I haven't tied that to the idle time scheduler yet. Shouldn't be a big issue.
Bomberman94
Wow I like this one! Could be 90% of a real game level and might become a clever action/strategy mix in the end. The ,,problem" could be the resolution (given the 2600 restrictions of course) - much elements on a small visible screen (building boundaries to solve a level is a good example here). Also your choice of colors and drawing the man and many elements you use are top notch.
