New weapon - flaming ball
Here's a study for a new weapon. Kind of a mace on a chain.
It destroys everything, basically.  So if you aren't careful you can cause rocks above you to fall, killing you pretty quickly. I die a number of times in the video.
I changed the particle system to draw coloured particles for this. Works well, and I'll go back and update all of the particle usage to use appropriate colours, soon.
A bit of work on this -- now it extends when you press the button and retracts when you release. Also I've modified the movement-behaviour. It's kind of "bendy" now.  There's a binary for you to play with - the mace, as it's called, is available on the first level.
