VSCodium (=VS Code) code format
I adore clang automatic code formatting. Once I configure the style I like, each source file gets auto-formatted on save.  So I don't particularly worry about formatting neatly when typing in stuff. I just churn it out, bad indents and all.  The format fixes it all.  It makes all code super-consistent.
To configure... install clangd extension as your code parser.
In VSCodium settings, search for 'format' and you should see the following...  just click format on save, and make sure the save after delay is not enabled (per the warning shown).  You can modify the format preferences by editing the .clang-format file in the project root directory.  Mine is attached here. You should, of course, use my formatting style as it's the best!
In code you don't want auto-formatted, such as static array inits, bracket like this...
// clang-format off
enum AttributeAlias {
    ROL = ATT_ROLL,                     // doge should roll off this object
    CVT = ATT_CONVERT,                  // iff below surface, object converts to lava or water
    XPD = ATT_EXPLODABLE,               // object is destroyed in explosions
    PER = ATT_PERMEABLE,                // square is 'permeable' (not solid/not blank)
    SPC = ATT_BLANK,                    // object is blank
    DRT = ATT_DIRT,                     // object is dirt
    GRB = ATT_GRAB,                     // doge
    PSH = ATT_PUSH,
    SQB = ATT_SQUASHABLE_TO_BLANKS,
    HRD = ATT_HARD,                     // Hard. rocks create dust when falling onto
    XIT = ATT_EXIT,
    QUI = ATT_NOROCKNOISE,
    RKF = ATT_BLANKISH,
    MIN = ATT_MINE,
    WTF = ATT_WATERFLOW,
    CVY = ATT_CONVEYOR,
    GND = ATT_GRIND,
    PIP = ATT_PIPE,
    PH4 = ATT_PHASE4,                   // processed every 4 frames
    PH2 = ATT_PHASE2,                   // processed every 2 frames
    PH1 = ATT_PHASE1,                   // processed every 1 frame
    DIS = ATT_DISSOLVES,
    MLT = ATT_MELTS,
    DGE = ATT_GEODOGE,                  // a geodoge
    PAD = ATT_PAD,                      // add dirt corners to this object square
    CRU = ATT_CRUSHES,                  // object above crushes player
    CNR = ATT_CORNER,                   // this object contributes to making a dirt corner
const unsigned int Attribute[TYPE_MAX] = {
// see attribute.h "ObjectType"
#define _ 0
    // clang-format off
// CNR PAD DGE MLT DIS PH* PIP GND CVY WTF MIN RKF QUI XIT HRD SQB PSH GRB DRT SPC PER XPD CVT CRU ROL
    _ |PAD| _ | _ | _ | _ | _ | _ | _ | _ | _ |RKF|QUI| _ | _ | _ | _ | _ | _ |SPC|PER|XPD|CVT| _ | _  , // 00 TYPE_SPACE,
   CNR| _ | _ | _ |DIS| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |DRT| _ |PER|XPD|CVT| _ | _  , // 01 TYPE_DIRT,
    _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |HRD| _ | _ | _ | _ | _ | _ |XPD| _ | _ |ROL , // 02 TYPE_BRICKWALL,
    _ | _ | _ | _ | _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ |HRD| _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 03 TYPE_OUTBOX_PRE,
    _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |XIT| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 04 TYPE_OUTBOX,
    _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |HRD| _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 05 TYPE_STEELWALL,
    _ |PAD| _ |MLT| _ |PH1| _ |GND|CVY| _ |MIN| _ | _ | _ |HRD| _ |PSH| _ | _ | _ | _ |XPD| _ | _ |ROL , // 06 TYPE_ROCK,
    _ |PAD| _ |MLT| _ |PH4| _ |GND|CVY| _ | _ | _ | _ | _ | _ | _ |PSH|GRB| _ | _ | _ |XPD| _ | _ |ROL , // 07 TYPE_DOGE,
    _ |PAD| _ | _ | _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 08 TYPE_MELLON_HUSK_PRE,
    _ |PAD| _ | _ | _ |PH1| _ | _ | _ | _ | _ |RKF|QUI| _ | _ |SQB|PSH| _ | _ | _ | _ |XPD| _ | _ | _  , // 09 TYPE_MELLON_HUSK,
   CNR|PAD| _ | _ |DIS|PH4| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |DRT| _ |PER|XPD| _ | _ | _  , // 10 TYPE_PEBBLE1,
    _ |PAD| _ | _ | _ |PH2| _ | _ | _ | _ | _ |RKF|QUI| _ | _ | _ | _ | _ | _ |SPC|PER|XPD| _ | _ | _  , // 11 TYPE_DUST_0,
    _ |PAD| _ | _ | _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |PSH| _ | _ | _ | _ |XPD| _ | _ |ROL , // 12 TYPE_DOGE_FALLING,
    _ |PAD| _ | _ | _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ |HRD| _ |PSH| _ | _ | _ | _ |XPD| _ |CRU| _  , // 13 TYPE_ROCK_FALLING,
    _ |PAD| _ | _ | _ |PH2| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |SPC|PER|XPD| _ | _ | _  , // 14 TYPE_DUST_ROCK,
    _ |PAD| _ |MLT| _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |XPD| _ | _ |ROL , // 15 TYPE_CONVERT_GEODE_TO_DOGE
    _ | _ | _ | _ | _ |PH1|PIP| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |ROL , // 16 TYPE_PUSHER,
    _ | _ | _ | _ | _ |PH1|PIP| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 17 TYPE_PUSHER_VERT,
    _ |PAD| _ | _ | _ |PH4| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 18 TYPE_WYRM,
    _ |PAD|DGE|MLT| _ |PH2| _ |GND|CVY| _ |MIN| _ | _ | _ |HRD| _ |PSH| _ | _ | _ | _ |XPD| _ | _ |ROL , // 19 TYPE_GEODOGE,
    _ |PAD| _ | _ | _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ |HRD| _ |PSH| _ | _ | _ | _ |XPD| _ |CRU| _  , // 20 TYPE_GEODOGE_FALLING,
    _ | _ | _ | _ | _ |PH1| _ | _ | _ | _ | _ |RKF| _ | _ | _ | _ | _ | _ | _ |SPC|PER| _ | _ | _ | _  , // 21 TYPE_LAVA,
   CNR|PAD| _ | _ |DIS|PH4| _ | _ | _ | _ | _ |RKF| _ | _ | _ | _ | _ | _ | _ | _ |PER|XPD| _ | _ | _  , // 22 TYPE_PEBBLE_ROCK,
    _ | _ | _ | _ | _ |PH1| _ | _ | _ | _ | _ |RKF| _ | _ | _ | _ | _ | _ |DRT| _ |PER|XPD| _ | _ | _  , // 23 TYPE_FLIP_GRAVITY
    _ | _ | _ | _ | _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ |HRD| _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 24 TYPE_BLOCK
    _ |PAD| _ | _ | _ |PH4| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |ROL , // 25 TYPE_GRINDER
    _ | _ | _ | _ | _ |PH4|PIP| _ | _ | _ | _ | _ | _ | _ |HRD| _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 26 TYPE_HUB
    _ | _ | _ | _ | _ |PH1| _ | _ | _ | _ | _ |RKF| _ | _ | _ | _ | _ | _ | _ |SPC|PER|XPD| _ | _ | _  , // 27 TYPE_WATER
    _ | _ | _ | _ |DIS|PH1| _ | _ | _ |WTF| _ |RKF| _ | _ | _ | _ | _ | _ | _ |SPC|PER|XPD|CVT| _ | _  , // 28 TYPE_WATERFLOW0
    _ | _ | _ | _ |DIS|PH1| _ | _ | _ |WTF| _ |RKF| _ | _ | _ | _ | _ | _ | _ |SPC|PER|XPD|CVT| _ | _  , // 29 TYPE_WATERFLOW1
    _ | _ | _ | _ |DIS|PH1| _ | _ | _ |WTF| _ |RKF| _ | _ | _ | _ | _ | _ | _ |SPC|PER|XPD|CVT| _ | _  , // 30 TYPE_WATERFLOW2
    _ | _ | _ | _ |DIS|PH1| _ | _ | _ |WTF| _ |RKF| _ | _ | _ | _ | _ | _ | _ |SPC|PER|XPD|CVT| _ | _  , // 31 TYPE_WATERFLOW3
    _ | _ | _ | _ |DIS|PH1| _ | _ | _ |WTF| _ |RKF| _ | _ | _ | _ | _ | _ | _ |SPC|PER|XPD|CVT| _ | _  , // 32 TYPE_WATERFLOW4
    _ |PAD| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 33 TYPE_TAP
    _ | _ | _ | _ | _ |PH1|PIP| _ | _ |WTF| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 34 TYPE_OUTLET
    _ |PAD| _ | _ | _ |PH4| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |ROL , // 35 TYPE_GRINDER1
    _ |PAD| _ | _ | _ |PH2| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |ROL , // 36 TYPE_BELT
    _ |PAD| _ | _ | _ |PH2| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |ROL , // 37 TYPE_BELT_1
    _ | _ | _ | _ | _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _  , // 38 TYPE_CONVERT_PIPE
    _ |PAD| _ | _ | _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |PSH| _ | _ | _ | _ |XPD| _ | _ | _  , // 39 TYPE_DOGE_FALLING2
    _ |PAD| _ | _ |DIS|PH4| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |XPD| _ | _ | _  , // 40 TYPE_ROCK_PEBBLE
    _ | _ | _ | _ | _ |PH1| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |ROL , // 41 TYPE_ELECTRIC
    _ | _ | _ | _ | _ |PH4| _ | _ | _ | _ |MIN| _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ | _ |ROL , // 41 TYPE_INSULATOR
    // clang-format on
