BONUS LEVEL idea
In this bonus level idea, you have to collect all of the doge and none of the stars. The level will end as soon as you collect a star.  So the first run through I manage to do it. Other runs - not so successful.
It looks/works better with rocks, I think.
Bomberman94
Great idea for a bonus level - you can easily make it more difficult from time to time. Will you get a specific bonus score or a another life? And will you get a score depending how many items you have collected or only if you master the level? Maybe both - a score depending... and an extra life when you clear the level completely.
Quote from: Bomberman94 on 14 Jun 2026, 10:07 PMGreat idea for a bonus level - you can easily make it more difficult from time to time. Will you get a specific bonus score or a another life? And will you get a score depending how many items you have collected or only if you master the level? Maybe both - a score depending... and an extra life when you clear the level completely.
Not sure. Maybe I'll have a "time bank" and you get extra time for later levels, depending on how quickly you complete the bonus levels.  All "to be decided" at this stage.
The 'locked' screen used for the bonus level is indicated by setting two flags in the cave definition. Specifically, if the cave data has CAVEDATA_LOCK_X and CAVEDATA_LOCK_Y set, then the scroll system is hardwired to show a particular part of the board.
What's been bugging me is that it's impossible to center in X.  Consider 40 PF pixels wide; we end up with 3 pixels of one character left edge, then 7 chars (x 5 pixels) = 35 pixels of play area, then 2 pixels of one character right edge. That's 40 pixels of PF.  What bugs me is the imbalance between the left margin and the right margin.
I realised I can fix this at draw-time by detecting that CAVEDATA_LOCK_X is set - in which case we know there's no x scrolling. I simply mask out the very leftmost pixel of the screen when it's drawn. Problem solved.  Image shows a *39* pixel wide screen that nobody will ever know is one pixel lopped off the left side, just because I'm perfectionist.
Bomberman94
What about a slight movement from left to right when standing still (,,shuffle from one side to the other") - a kind of waiting for a joystick input from the player.
Quote from: Bomberman94 on 15 Jun 2026, 04:57 AMWhat about a slight movement from left to right when standing still (,,shuffle from one side to the other") - a kind of waiting for a joystick input from the player.
Yes, planned.  "Idle animations" as I call them.
#7
This one works pretty well.  You have to get ALL the doge coin before you can get ANY of the stars. The stars are on an escalating destruction timer, and blow up. You need to try and optimise your doge-coin gathering to do it quickly and have as many as possible stars left.
Looks like the sound on the video is totally out of sync...!
Binary attached, which gives a better idea of the SFX.  SELECT or RESET to replay.
How many stars can you collect?!!
Eat all the coins first, then gather the remaining stars.
