Planets, levels, etc.
I think I'm going to settle on 100 levels.
Specfically, 10 planets, each with 10 zones. Maybe two of those being bonus.
On each planet you'll play areas from pole to pole.
I'm going to try and have a different partial character set belonging to each planet. That is, the base characters (64) + planet characters (64).  That may be tricky, but it's a goal.
I like the GridLock Level display on the menu screen. I'm going to use something similar. You'll have to unlock further planets by first completeing earlier ones. Progress saved on SaveKey.
I think I'll also put a planet/level preview on the menu, just like GridLock and Boulder Dash.
On a way-out-there idea, maybe I'll change it to a jumping platformer to further distinguish it from BD. Not sure on that, but it bothers me some of the similarities still. I don't want people to say "it's Boulder Dash in space", for example. I have to make it sufficiently different that that won't happen.
So, that's the immediate future. More levels, work on the menu screen, work on the preview thumbnail, work on custom character sets for each level.
Also planned: import/rewrite the spinning planets as an interlude screen, import the huge skull as a death sequence.
Bomberman94
I like the idea of different themed planets! I think of a cold planet with white and blue as well as hot planets with red and yellow and so on. Maybe like Starfox: having a small selection of different routes and one planet after the other including bonus intermissions. Not sure if a ,,route overview" or kind of a map is possible/feasible on the 2600...
Quote from: Bomberman94 on 16 Jun 2026, 07:00 PMI like the idea of different themed planets! I think of a cold planet with white and blue as well as hot planets with red and yellow and so on. Maybe like Starfox: having a small selection of different routes and one planet after the other including bonus intermissions. Not sure if a ,,route overview" or kind of a map is possible/feasible on the 2600...
Yes, something like that!  I have a sort of vision of a schematic of the solar system.
