Mace weapon under joystick control
The mace weapon was previously completely random - you just held the button and the mace swung around you on a chain/rope.  I've made a small change to make it joystick controlled. If, and only if, you are completely blocked by "hard" objects (brick wall, steel wall, closed door), then you can control the direction (left/right for alternate rotation changes) and length (button held duration). It's actually quite nice and fun to clear the level using the mace.
Video shows me doing it quite a few times. Attached binary should work.  Hold button to engage mace. Use left to rotate in one direction, right in the other direction. If you don't hold left or right, then the mace will wobble a bit, by design.
Hit select or reset to exit the level and see the death skull.
I really like this first level as a bonus level. It looks gorgeous.
Bomberman94
Last playable binary (WenHopPlanetPluto_20260617@20_16_44.bin):
- title screen is OK
- skull screen is OK
- ingame screen is still not stable (less than before but still there)
Please see some screenshots:
Quote from: Bomberman94 on 21 Jun 2026, 11:12 PMLast playable binary (WenHopPlanetPluto_20260617@20_16_44.bin):
TY for testing. I'm aware this isn't working on hardware at the moment.
I am not addressing/fixing this issue until later. Binaries emulator-compatible only, for now.
