spinning planet info screen
I've got a rudimentary spinning planet working.
Lots of glitches, and not using the correct ChronoColour version yet.
It's just using the board as the texture map at the moment.
In the final version, I'll draw the continents, or at least a representation of them, for each planet.
It should look rather nice.
Good to have the fundamentals - even if glitchy - basically working.
Now with proper PCC (phased chronocolour).
I also slowed down the spin; there's a balance between being blocky and spin speed.
Anyway, progress.
Bomberman94
Wow - unbelievable and hard to imagine that this is (only) a 2600. This type of intro fits perfectly well to the playing levels!
Quote from: Bomberman94 on 18 Jun 2026, 07:57 AMWow - unbelievable and hard to imagine that this is (only) a 2600. This type of intro fits perfectly well to the playing levels!
This is just the prototype. i have plans to make it look better, in higher resolution.
Fingers crossed!
I've added a generic "proportional font" printing system, and in the video I'm using it with a few different-sized fonts for the planet info.
The really nice thing about the whole system is that I draw the font in an image, and that's all I need to do. I have a tool that splits individual characters out from that image, figures out their width, and creates the C source/tables for accessing them.  It's a fully automatic system, super cool.
There are a few funny planet descriptions in this video. I may keep them.
Binary attached -- there's some basic sound as the text is being output.
Won't run on hardware - or at least won't run on the dev carts that seem problematic. I'm gonna fix that someday, but not today. Use an emulator.
#5
It's looking pretty polished now.
I added some "fun" text describing some of the planets.
Propane13
I know I don't show up here often, but I did want to say I noticed the text overlap issue on an earlier build, and it looks much better now!
This is a fantastic demo.
There were only 2 things that I might consider tweaking a tiny bit.
1. I'm guessing the stars matching the planet color is a consequence of the engine?  Seeing them as blue / green / etc, looked a little strange.  I would say that the Brimston layout was better than the Neptune, probably just because they felt more "oh it's everywhere" vs. Neptune which looked a little like rendering artifacts or errors from shrinking the planet.
2. I would left-justify all text.  The delay on reading a few of the planets' words from line to line is noticeable.  I'm guessing the Brimston's "filth" is supposed to be delayed to make it funnier, which lands. But, you could stretch out the time with a ..... in the previous sentence".
Overall, it looks great, and I do like the sound effects that play when rendering text.  Good stuff!
Quote from: Propane13 on 24 Jun 2026, 06:07 AM1. I'm guessing the stars matching the planet color is a consequence of the engine?  Seeing them as blue / green / etc, looked a little strange.  I would say that the Brimston layout was better than the Neptune, probably just because they felt more "oh it's everywhere" vs. Neptune which looked a little like rendering artifacts or errors from shrinking the planet.
Yes, stars match the planet colour. I choose between the 7 colours randomly. I can hardwire it to one of them. I haven't settled on which, yet.  They are also positioned randomly, which is easy. Sometimes things will look better than others.
Quote2. I would left-justify all text.  The delay on reading a few of the planets' words from line to line is noticeable.  I'm guessing the Brimston's "filth" is supposed to be delayed to make it funnier, which lands. But, you could stretch out the time with a ..... in the previous sentence".
I'll skip all spacing in one go - that will fix the delay. I'm not sure on justification at the moment, but I am leaning towards having a quotation type thing there, which would lend itself to justified. We'll see.  The sound is out of sync in the video - a bug in the video capture/renderer. That will hopefully be fixed one day.
Some funny 'TripAdvisor' reviews for the planets...
Philsan
With that engine even a Solar System application would be possible!
Quote from: Philsan on 26 Jun 2026, 10:51 PMWith that engine even a Solar System application would be possible!
Yes. Saturn is the problem. But in principle, could do all the planets and moons.
I've done some work on texture generation - in particular, larger areas of static colour (i.e, reduced frequency of the texture). I've also optimised a bit for speed, though that won't be enough on hardware/Stella yet. I think.
So, the video does a 2x10 planet sequence. Mostly just to see some of the reviews, which I'm really enjoying adding.  Some are great, some so-so. I'll cull to a list of great eventually.
The thing to really "notice" here is the improved texture visuals -- much less 'shimmery'.
