New display technology -- "RasterBleed"
I have a "top secret" new display technology I call "rasterBleed".  *COMPLETELY* different to ChronoColour. It's in the genesis "does it work?" stages.  No apparent flicker - at least under Gopher and Stella.  The image is rather hard to see, and washed out at the moment.  I thought I'd at least dump some in-progress screenshots.
It may work out, it may not.  But it's a super-interesting method/idea so I'll post progress here as we go.
Here's the first-ever image...
Very unsure if it's going to work. Maybe not for complex images; certainly for much simpler images. Here's the 2nd demo image after some tweaks...
Some glitches in the conversion (a bug), but certain images are going to look fantastic.
It may not be super-generic in the high-colour-noisy images, but this one is great.
Next I'll try the parrot.
Bomberman94
Interesting - worth to try and see...
There's some flicker/shimmer. Not a lot. More evident on bright colours.
I'm working on it. Still, quite promising -- at least for some images. Perhaps not universal.
Not the greatest. But interesting.  Will keep on tweakin!
#6
I added a new technique to mask the flicker/shimmer. Dramatically improved.
Binary attached -- you can at least see that I'm onto something. I think!
Each image takes the tool around 2 minutes to process on my M4 MacBook.
There's an immense amount of calculation going on to create the data for these images.
But it seems to work - at least somewhat!  ToyStory one is hard to make out.
Will work for PF images, too.
Philsan
Rastaconverter conversion on A8 need hours, not minutes, therefore I don't see problems ah ah.
rbairos
Cool. some of the images come out clearer.
What type of resolution are you getting?
Bomberman94
Colors are nice and clear especially at Donald and Uncle Sam - bigger areas of single colors seems to work better.
Do you recognize other regions or do they only fit NTSC Ataris?
Quote from: rbairos on 06 Jul 2026, 05:20 AMCool. some of the images come out clearer.
I'm not sure what you're asking.
The tool is passed the destination resolution, and resolves the frames based on that.
So in the examples shown, 48 wide x n deep x 3 frames.  That is, a 6-sprite routine.  It can easily do PF resolution 40 x n or anything really. Congifured on command line.
Each frame can be displayed independently, though, and the system is incremental. That is, if you display just the first frame it's recognisable but bad. If you add the second frame (ie, display ABABAB) then it's much improved. If you display the third ABCABCABC even better. It's optimised for 3, in that I have an added interleave there to reduce any pulsing that might occur.
On the other hand, the pulsing is already minimised by the tool which is aware of that effect and encodes to minimise that anyway.  Combined the pulsing minimisation with interleave with 3 frame cycles and the eye distractions are quite minimal.
But it's not limited to 3 frames, either. You can have as many frames as you want, each contributing to the blended result. At the cost, of course, of increasing 'shimmer/flicker' but improved colour resolution/correctness. It's really interesting.
The tool also allows configurable 'passes' to improve the image. If I let it run longer, to some extent, the quality of the result improves. It's really interesting, too. At the moment I have it set to a "lowish" value to allow me to test binaries more quickly.
Quote from: Bomberman94 on 06 Jul 2026, 05:35 AMColors are nice and clear especially at Donald and Uncle Sam - bigger areas of single colors seems to work better.
There was simply a missing 'convertColour(...)' call there, as it was a first-pass prototype.
The attached version has this added now, and the colours will be correct on PAL and NTSC. AND SECAM! You'll notice it now fades in, too -- an automatic consequence of calling 'convertColour' no matter what the system.
From now, the hard part is tweaking the parameters for each image. There are a lot of them. It's clearly going to work for larger areas of solid colour. So, some images but not others. It's still pretty neat when it does work.
It's not suited to everything. But some things come out gorgeous.
Particularly, subtle shading and colours can be awesome.  Here's a great one...
Bomberman94
Quote from: Andrew Davie on 06 Jul 2026, 05:56 PMIt's not suited to everything. But some things come out gorgeous.
😲unbelievable that this one is an actual image on the 2600!
Quote from: Bomberman94 on 06 Jul 2026, 07:35 PM😲unbelievable that this one is an actual image on the 2600!
I have confidence it works, but haven't actually seen it!
Image shows how subtle colour variations can be. I upped the hues just a bit.
