Picking up things!
I've just added the ability to pick up things!
Direction+joystick will pick up an object in that direction -- iff it can be picked up.  Rock, GeoDoge, Star at the moment.  You carry the object around as you move.  To drop the object, joystick+direction. If the square is "available" the object is placed there, otherwise it just disappears.
It's pretty awesome; will add a whole new dimension to gameplay.  Very first version - just a few minutes old. Colours of the picked-up object are wrong; will fix soon.
update:  picked up objects are now the correct 'base' character and colour.
#2
Some gameplay thoughts with pickup. You can...
1) build obstacles to block off entrances/exits
2) carry a doge and 'pay' for something (a tollgate, for example, to open a door)
3) build large blocks of geodoge (we could make converting geodoge more points based on block size)
4) Destroy objects by dropping them under the electric fence
5) maybe carry an item from one level to another!!
#3
Animation of the picked-up object is now installed. Nice.
TODO: also animate dropping/placing the object.
As you see by the video, if you understand the control system (button+direction), it's really easy to do accurate placement of objects.  I made it so that you can also pickup the exit door -- which is pretty strange - and place it somewhere else. Might make a nice gameplay element later.
I'll only add hardware (120K) binaries once I get the timing issues fixed.  For now, emulator only.
alex_79
Very nice!
The horizontal movement animation is convincing, which is not obvious given it mixes sprites and playfield, with the latter having 1/4 of "movement" resolution.
Quote from: alex_79 on 12 Jul 2026, 05:47 PMVery nice!
Yes, I was surprised it worked so well! I thought that resolution difference might be a problem.
I've added a throw/drop sequence for the carried object.  Looks good.
In this video I twice - or three times - managed to get through "impassable" electric fences. That is, a fence which has a vertical wall on the other side. Not enough time to mine through the boulder/geodoge. Previously impossible. Now, as you see in the video, there's just enough time to rush in, pick up one of the barrier objects, and rush back out again.  This frees a gap on the other side of the electric fence that allows access.  It's an awesome gameplay element already.
Why would you want to pick up the exit door?  I'm thinking of a scenario where you have to get a certain numbe of dogecoin to open the door, and there's lava -- and by the time you get the coins the lava has destroyed the door. You could pick up the door, move it higher, collect the doge. It would be a very non-obvious way of completing a seemingly impossible level.
Here's a credible use-case for picking up a door.  The mace weapon will collect doge (and convert geodoge to doge) so in the attached level you can get all the coin. But you can't get the star - because the mace weapon doesn't affect it.  But, if you collect enough doge and the door opens (starts flashing), instead of going through the door (no button), you instead pickup the door (button+up) then you can exit from the central area, put the door somewhere esle, go and collect the rest of the geo/doge and the star... and THEN go through the door.
It's unusual. Interesting.
