Programming monitor
SpiceWare
I recently retired my treadmill desk and decided to get a 3rd monitor after setting my original desk back up.
I discovered that BenQ has a line of Programming Monitors with features that target programers. The one that piqued my interest was 3:2 aspect ratio of the RD280UG as I've found 16:9 to not be ideal for coding.
Apparently it's a popular model as all the US resellers were out of stock. I was finally able to purchase one on Amazon, though I see it's sold out again.
The DPI of 163 is the same as my existing Dell 4K monitors, so windows stay the same size when moved between displays. The BenQ has a 4k+ display, which is 3840x2560 vs the 3840x2160 of the Dells.  It also features 120 Hz and HDR, which both my work PC and Mac Studio support. My PC is connected via DisplayPort while the Mac is connected via USB-C.
Picture quality is great, the extra vertical space is very useful, the nano matte finish cuts down on reflections, and I was surprised to find 120 Hz was a noticeable improvement over 60 Hz. I used UFO Test to evaluate the refresh rate.
Overall I've been quite happy with it. I plan to eventually purchase 2 more and retire the Dells to other uses.
The monitor does feature a built in KVM which I used for a while, but stopped due to a major flaw. It won't switch the keyboard/mouse to the other computer if it's not receiving a video signal, so if you've been working log enough for the other computer to go to sleep you cannot wake it up without temporarily plugging the keyboard directly into the sleeping computer.
I left a review on Amazon, you'll have to locate it as I discovered using the direct link results in a logon prompt. A text search for Spice should take you right to it. When I wrote the review I was still using the KVM, but I've since decided I didn't like the workaround of my computers never sleeping.
Nathan Strum
I've got a pair of matching BenQ graphic design monitors, and they've been the best monitors I've owned. They do have the odd bug with the KVM switch you mentioned. My workaround is that I keep a second small keyboard (or any USB input device would work) plugged directly into my main computer, and just sitting out of the way on a shelf. So when I switch to my secondary computer (which is rare), and the main one falls asleep, I can just tap that other keyboard to wake it back up, then the KVM works fine. (Not ideal, but it does work. I've mentioned it to BenQ, but it's not something that's fixable. I blame Apple.)
For the CHAMP GAMES booth at PRGE, we use BenQ's Mobiuz gaming monitors for our Atari "plus" systems and most of our original consoles (with RetroTink scalers). Acquiring, repairing, maintaining, storing and transporting CRTs was just a non-starter. Especially for one weekend a year. The gaming monitors are about $150 USD each. You just can't match that cost with any CRT.
SpiceWare
That's a bummer it's not fixable.
I ended up using an old IOGEAR 2 Port USB 2.0 switch I found in my cable bin.  I used it a long time ago to share a printer between my work computer and Mac. Works well though the Mac launches the Keyboard Setup Assistant every time I switch over to the PC, at least it automatically closes it when I switch back.
I had planning to order the another one of the monitors this week, but ended up having an expensive weekend.  I'd noticed everything in the freezer compartment of my fridge was unthawed. A bit later I noticed a small amount of water come out the bottom of the control panel - apparently the in-door ice maker/water dispenser sprung a slow leak and shorted out the freezer circuit as the fridge section was still at the correct temperature.
SpiceWare
After a couple months I noticed the solid blue color that macOS uses throughout the system to show things like selected items, your responses in Messages, etc. had a subtle scanline like appearance.
Started looking around and noticed a new 4 star review at Amazon that mentions it:
QuoteAt 120Hz, it suffers the famous "every other pixel row is dimmer" for certain solid colors at high Hz. No problem at 60Hz or 100Hz. At 120Hz, it happens particularly on cyan-blue and orange.
Sure enough - solid orange as well as solid yellow also exhibited the problem, and dropping down to 100 Hz cleared it up.
I wasn't able to find anything else so asked Grok about it, which said it's an LCD pixel inversion artifact:
QuoteLCD pixels must flip between positive and negative drive voltage every frame so DC charge doesn't build up and cause image retention. When that polarity scheme isn't perfectly balanced at a given timing, the two polarity states look slightly different. On large flat areas that difference shows up as faint scanlines, an interlaced look, or a fine mesh—especially on mid-tone blues, cyans, and oranges.
Link to full response.
Overall it's a minor issue and I still plan to get 2 more of these monitors.
SpiceWare
#4
Second programming monitor acquired!
Due to the end-of-year expenses (holidays, HOA dues, and property taxes) the third will be sometime next year.
