A level playthrough
Slowly removing glitches. Here's a full level gameplay.
The on-the-run pickup as you go past the electric fence is pretty cool. Some sections have this at the only way to get past the fence (e.g., at 0:28). Gotta be careful there's not anything above the pickup object, though, or you get crushed.
Another playthrough, with the swipes operational. Tightening up the timing.
Up till now I've had a weird crash (overtime). Fingers crossed... haven't seen it for a few runs.
Yet another playthrough - planet intermission screens now stable, too!
There was an incredibly obscure bug found in this round -- I would modify the planet height starting point, and the *copyright* kernel would crash.  Only the planet code had not been called at that point. In other words, "spooky action at a distance".  If I disabled the '-flto' flag in the link/build (which is an optimisation flag) then all worked OK.  In fact if I modified anything inside the planet code, then the copyright (or the skull, or the detectkernel) would crash. Bizarre!
Eventually tracked down to a warning in the compile -- the drawGridPreview (on the menu screen) iterated 11 lines instead of 10. I'd ignored this warning as a "fix later", but in fact - even though the code was never called - it was enough to allow the optimiser to effectively break things with its code reordering.  Lesson learned - one I already knew - treat warnings as errors. But this was the absolute weirdest one I've ever seen.
Fixed the code in question - even though it *never ran* -- and everything is now working properly.
Video shows a long playthrough with many systems functional.
#3
Another playthrough. Lots of updates to the timing. Noticeable slowdown in some (very complex) areas where a lot is happening. But not too bad - and in any case I won't have screens that complex anyway.  One crash observed. It's a time overflow issue - will hunt it down eventually.  The new auto-timing code is working very effectively - not many time overflows in this one. Very few, actually. Well, maybe none?  In any case, it will only get better.
