Menu level status grid
To indicate progress through the 100 levels planned (10 planets x 10 locations in each), I plan to have a status grid on the menu screen -- very close to that in GridLock.  Each line of the grid indicates one planet - and planets will be 'locked' until you complete certain requirements in earlier planets.  In GridLock, I had solved and solved perfectly; not sure if I'll have that for WenHop, or something different.
In any case, I've borrowed the code from GridLock and it's basically slotted in after a bit of manhandling. Obviously extremely rudimentary for this first version, but this will be the thread to watch for updates to that part of the game.
#1
Coming together. A bit different to GridLock, already.
#2
Here's a binary.
Nothing to do on the menu screen; just eye candy showing the progress grid.
Actually... just for a bit of fun I put a game of life running in the grid.
In the levels, pickup/drop is simply button+direction = pickup
button+direction = drop
Bomberman94
I think this is the best you can do while showing the stats of 100 levels within the title screen! If you're willing to spend this an extra screen you may show a starting point and a connection to the next possible planets instead. So the player can plan his own ,,route" to reach the goal at the other side. ... just another approach
