rock stable kernel transitions
Worked on the transitions between kernels (menu/game/copyright) so that scanlines are 262 without any jumps or breaks. Feels rock-solid now.  Binary attached.
Bomberman94
In case you want to know if this runs on the real thing, please can you make a 120 KB version? I would be happy to play/test at the weekend latest 😌
Quote from: Bomberman94 on 22 Jul 2026, 04:37 AMIn case you want to know if this runs on the real thing, please can you make a 120 KB version? I would be happy to play/test at the weekend latest 😌
Thanks, but the DEV cart is currently incompatible for unknown reasons. Until I get to understanding the timing on that, the binaries simply don't work and not worth testing.
JetSetIlly
Quote from: Andrew Davie on 22 Jul 2026, 04:59 AM
Does Bomberman have a 60Mhz or 70Mhz dev cart? If he has a 70Mhz dev cart, it might work.
@jetsetilly.bsky.social
#4
Quote from: JetSetIlly on 22 Jul 2026, 05:14 AMDoes Bomberman have a 60Mhz or 70Mhz dev cart? If he has a 70Mhz dev cart, it might work.
I think all DEV carts don't work, but worth a try I guess.
Binary attached!
Edit:  _120K binary for DEV cart, the other for emulators.
Bomberman94
Quote from: Andrew Davie on 22 Jul 2026, 05:41 AM
Binary attached!
Yes, my DEV cart also have problems: just for the records, screen jumps while the planet gets bigger and zooms out/in and while gameplay.
