game mechanics - weight/barrier
Here's a new idea - a barrier which collapses under "great weight".
In the video I'm piling rocks on top of the wavy platform/barrier.
When I get to >10 rocks (across the whole barrier), it collapses and the rocks fall.
The idea here is that the barrier can prevent you getting places, so you have to break through by moving a whole bunch of rocks on top of it. Video gives a pretty good idea of gameplay.
Current implementation - there could be one of these per level, though I can sort of see ways to improve that to multiple.
Here's a little "bonus screen" I designed to show the basic gameplay mechanics.
Pile 9 boulders on top of the barrier to break through, then move all the "debris" out of the way... and get the stars.
Bomberman94
Great idea - maybe you can give an indication that the weight almost break the barrier (e.g. two more rocks needed and it shakes a bit and one more left it shakes more). Fantastic that you also take into account that the position of the rocks influence the load-bearing capacity of the barrier!
Another idea: the color of the barrier could indicate the weight until it breaks.
Quote from: Bomberman94 on 22 Jul 2026, 10:27 PMGreat idea - maybe you can give an indication that the weight almost break the barrier (e.g. two more rocks needed and it shakes a bit and one more left it shakes more). Fantastic that you also take into account that the position of the rocks influence the load-bearing capacity of the barrier!
In the recent post (where I introduce the bomb), you can see the barrier animation speeds up as more weight is added. It's a start - I may find other ways of showing it more clearly. Thanks for the suggestions.
I've worked on the visuals a bit.  Shaking the screen when you drop a geodoge or boulder on top of a weight/barrier. Note that you drop the object on top of other objects that are on top of the barrier - as long as the chain of objects contributes to weight, and they are eventually on top of the barrier (which I call "cracked bricks" now), then the screen will shake and a bunch of debris will fall off the barrier. It works nicely to allow a less visual transition through the stages of barrier disintegration.
