Pengo
Just a quick-n-dirty test using the current engine to see what issues would be involved in a Pengo implementation.
Bomberman94
I love Pengo and a ,,spin off" with your engine makes completely sense! Please let this come true 🐧
Al_Nafuur
Quote from: Andrew Davie on 16 Aug 2026, 08:08 PMJust a quick-n-dirty test using the current engine to see what issues would be involved in a Pengo implementation.
This looks really good! The slightly larger Pengo and Sno-Bees don't really stand out because of how smooth and natural the scrolling is. A little more work on the graphics would probably get them very close to the arcade look.
Basically just a title screen, and you have a project with this engine finished and out the door... 😉
Quote from: Al_Nafuur on 17 Aug 2026, 05:13 PM
Agreed it looks OK. But there are real playability concerns. When you push a block and it kills a Sno-Bee, that is more likely than not to be offscreen. I think it's a large part of the playability - seeing the whole board at once.  So I'm unconvinced this is a viable way of doing Pengo.
Bomberman94
Are you able to make the penguin and ice blocks smaller to fit everything in one screen? That would solve the ,,push it out of sight" problem.
By the way a Dig Dug could be another use case for this then?
Quote from: Bomberman94 on 17 Aug 2026, 08:27 PMAre you able to make the penguin and ice blocks smaller to fit everything in one screen? That would solve the ,,push it out of sight" problem.
The engine can display characters of arbitrary size.  Currently 5x10 "trixels".  The visible screen is 40x66 trixels.  So, well yes in principle. But with lowering resolution things start to look .... not like things, and more like colour blobs.
Dig dug would be possible. Even easy, yes. But there's already an incredible DigDug for the '2600 so I wouldn't tackle that.
Al_Nafuur
Maybe the NES game Bomberman is a better fit for the engine.
There is a port to the 2600 by cd-w called Boom!
https://forums.atariage.com/topic/336441-boom-atari-2600
but this port doesn't support the UnoCart/PlusCart
