Longplay
I am creating this "longplay" thread for videos of gameplay. I think we're now at the point where I'll be focussing more on the actual mechanics of levels than creating new objects.
#1
Here I attempt to play 10 levels, constituting a complete "planet".  The chosen levels are just ones from the pool of already-designed levels. In the final version, planets will be themed (water, lava, etc) and increase in difficulty.
Note, some of the levels are "fiendishly difficult" and at least one is impassable. In those cases, I have hit SELECT/RESET, which has the effect of opening the door and putting the player right there -- effectively transitioning to the next level. I usually have a fair go first, and die a few times, just to give an idea of what the gameplay and level look like.
note: the audio gets a bit out of sync towards the end of this video.  Bummer.
#2
Here are some levels from the 2nd planet...
Also, I did some work on the landing/leaving sequence.
Note the "flames" on the rocket exhaust bounce off the ground. Details!
I've started (re)work on lava levels.  See around 5:40
#3
Here's another longplay.
I play through a number of levels -- sometimes SELECT to cheat/teleport to the next level.
The full game sequencing is in -- globe/landing/(play)+/leaving and repeat.
I have something like 20 levels installed. I play through some of those here.
There's a binary attached!  Remember to press SELECT to be a loser and cheat!
PS: the sound gets out of sync in the video, alas.
Whereas most of my videos receive a smattering of views - maybe 50 in the first week - that latest longplay video has received 1400 in the first day. I think it's been "featured" on YouTube's homepage for people. In any case, great to get that extra exposure.
I don't particularly enjoy having to "defend" the program, though. Explaining that many modern homebrews have extra RAM, for example. There are many "gatekeepers" out there who leave comments and seem to want to define what I can call an Atari 2600 game.
Feedback so far is that the music is horrible. Granted it's overkill. I'll work on selecting the best tracks and making things far more subtle.
The YouTube views on that last video are now up to 3000 (!) with 48 comments.
Here's the latest longplay.  A few bugs here and there, but it really is looking fine!
There may be some audio sync issues; still a not-perfect problem related to the recording not the game.
Here's another quite long longplay.
I found/fixed an obscure sprite bug which has caused an (un-noticed) one-frame black/flash for all animation whenever you start a move. Go figure.  Looks cleaner now; much.  In this video I'm just randomly picking levels and playing. I found one or two new ways to complete some of the levels.
The planet colours and rotations are borked. I've been playing with ideas in that part of the code.
It's coming along nicely, overall.
I managed to save about 800 bytes of RAM (I had 4 bytes left) by moving towards using overlays.
This video is uploading as I post this, so if it doesn't play give it a few minutes.
Bomberman94
Some thoughts:
- the "remaining time" or "stars to collect" pointer: the idea to give it a frame is good but maybe it is possible to simply make a bit smaller as it is very big and takes much space on the playfield (covers much playfield)
- sound: sound is unusual to my ears or say no real melody (hard to describe) - maybe you can lower the volume only of the sound to make it more like background tones
- a question: what is the difference between the anchor block and the one with the "X" on it?
Apart from that looks almost finished to me - eagerly waiting to play it on real 2600!
Quote from: Bomberman94 on 19 Sep 2026, 01:47 PM- the "remaining time" or "stars to collect" pointer: the idea to give it a frame is good but maybe it is possible to simply make a bit smaller as it is very big and takes much space on the playfield (covers much playfield)
Not sure what I'll be doing yet. I do llike the large digits. Making them less obscuring might be the way to go (offscreen, slide on when required)... dunno yet.  They're 4 trixels wide; 3 doesn't look quite as "stylish" to me.
Quote- sound: sound is unusual to my ears or say no real melody (hard to describe) - maybe you can lower the volume only of the sound to make it more like background tones
I'll come back to the sound when gameplay and levels are complete.
Quote- a question: what is the difference between the anchor block and the one with the "X" on it?
The "X" can be pushed left/right.  The "anchor" is immovable. It will fall, but cannot be pushed.
Quote from: Bomberman94 on 19 Sep 2026, 01:47 PM- a question: what is the difference between the anchor block and the one with the "X" on it?
I forgot, also...
The anchor will not crush you -- the "X" will.
Part of the game is learning what these things do, and how to use them effecively.
Also, a "huge" part of the game is knowing what you can lift/carry and realising you can carry things into other levels.
This time, with a binary.  Have fun.  Remember, it's a WIP and some screens are not completable.
And the linking between levels is non-intiutive; will fix. And well, who knows. Stuff.
Here's another longplay. This one shows extensive use of the new "look around" zoom.
I play many of the levels; it helps knowing the tricks :)
Bomberman94
Zooming around looks intuitive and very smooth and right size. I like how the man throws in the key to open a door.
