New level. Perhaps too unfair/tricky
In this cave, there are two doors and a key.
The middle door is locked.  The ONLY way to open it is to use the key.
If you use the key, you can go through the door, which exits you on the square to the right of the door.
Then you're in the right-side of the screen (with the door to your left now closed/locked).
You now have two locked doors and no key left to use.  How do you get out?
The solution -- perhaps a bit too obscure?  -- is this.
1. Do not use the key on the first door.
2. Pick up (!!!) the first door and move it out of the way
3. Pick up the key, go through the now open doorway (that no longer has a door)
4. Use the key on the door bottom right and exit the cave/level
Well, it works. Not sure if I'm going to use it.
Maybe on the later, super-hard, levels.
