Level preview, grid selection
I've done some work on the planet/level selection grid.
It's hooked into SaveKey now, so the levels you complete will be the same next time you insert the cartridge.  A long-press of the fire button will take you to a preview of the level, which you can scroll around.
Also changed -- a planet "opens" when you have 5 or more of the levels on the previous planet complete. And whenever you select a level on a planet different to that last played, you will get the planet info (globe) screen, and a landing sequence.
Propane13
Do you need to reserve a SaveKey slot?
This is fairly recent news, but some folks have worked to move the SaveKey slot reservation list to github:
https://github.com/atariage-community/savekey-allocation-list
I thought you might like to know!
Quote from: Propane13 on 02 Sep 2026, 11:10 AMDo you need to reserve a SaveKey slot?
TY. Yes, news to me. I'll get a reservation made soon!
#4
This screenshot is an example of what the grid will look like when you've played many of the levels. There are three "shades" -- dark = not completed, medium = you went through the door successfully, light = you also grabbed the required star. There's also a nice rainbow gradient on the rows themselves, just because I can.
It's a mockup simulating actual usage -- the lower planets are much more complete "achieved", and the upper planets very few "achieved".
The eventual goal would be for all to be light-coloured.
I have reserved slot 0x6C for "Wen Hop?" and I'm releasing the attached ROM that *uses* that slot, so that I can mark the record as "allocated" instead of "reserved".
This is a WIP video diary of my development of an Atari 2600 game "Wen Hop?".
I've done some more work on the selection grid.
Previously I'd coloured the unreachable levels in red - but this didn't let me differentiate between the locked levels, and those I hadn't implemented. In this new rendering, the NOT IMPLEMENTED levels flash slowly. I can now clearly see how may levels I've actually implemented.
I'll use that, though, when all the levels ARE implemented and have that flashing represent locked/unreachable levels.  Then the dark, solid for levels unlocked but not solved, medium solid for levels solved but not "achieved" (you got the star), and of course bright solid for levels you've aced.
The SaveKey is fully operational so the level status is preserved between runs.
Tried a "what-if?" experiment with the pCC colours on the grid preview. OMG!
Updated example of a populated grid with levels in various states.
I think we can call this part of the game superstructure "complete".
I'll be posting pCC screenshots as that's the default.
