New level - building a bomb platform
A new level - bit of randomness involved with the conglomerate -- but essentially you need to build a platform on the right to allow you to drop the bomb high enough to blast the wall around the key, then make your way back to open the door before the cave timer runs out.
Here's an update. I've worked on the visuals on the conglomerate disintegrating, and the timing of things. Also, levels now have names -- this is Cuniculus.
