new level - conveyors
I've started work on a level using the conveyor belts. I redraw them and they look mostly pretty cool. I have a few glitches to fix. I've started implementing their actual functionality - carrying objects left/right.  The screen here is a first demo, which is actually pretty cool to watch. I'll try and build in some genuine gameplay in the next few iterations.
#1
Some refinements.  Rocks now move on the belt at 1 PF pixel steps (=smoother).
I can set each conveyor's direction. The animation is always "left" at the moment; I will fix that up.
Lots of rocks in this video just to give some idea of "gameplay" such as it is.
Certainly feels like a totally different type of level.
more work on the conveyor belts. I have the movement smooth now - took me way longer than it should have. The interactions between various objects can become rather complex, particularly as the board is scanned top to bottom left to right.
I'e done a little work on the conveyor graphics. I think they're quite nice now.
I also put in a rudimentary "tap the wheel" to change the direction of the belt. If you watch this playthrough, you'll see the belts change direction every now ant then.
More work on the conveyors.
I added a grab (button+direction) of either end "wheel" to change the direction of the conveyor. There's also a visual direction arrow cue there. It should make for interesting gameplay.  I also fixed up the "partial character" that could be left behind if you changed direction while a rock was in mid-movement.
I *finally* got the direction and placement of the conveyor arrows correct. Took me quite a bit of effort -- there are 8 variants in all. Basically, when the system draws a direction arrow for the conveyors it attempts to place it in the least inconvenient place possible.
