advanced SpeakJet emulation now in Gopher!
Gopher emulator now natively supports SpeakJet (AtariVox) speech. It's pretty cool, allowing much much finer control over the SpeakJet chip.  The SpeakJet chip is now accurately emulated from first-principles - a clean-room implementation relying only on the technical documentation of the chip.
The upshot of all this is that the emulated speech sounds very similar to the speech output by the physical hardware. Many missing capabilities are now emulated - mid-word speed and pitch changes, the extra effects, and many more.
Grab a nightly build of Gopher, or build it yourself from the GitHub source code.
Attached is a binary full of speech for you to test.  Note that the current Stella emulator will NOT play the speech correctly, as it uses many of those aforementioned features that were not previously correctly emulated. Hopefully the Stella emulation will be updated, as the new SpeakJet code is public-domain and freely available. It is currenlty written in go, but a C implementation should be straightforward as the code is well documented.
