interlaced NTSC closed captions test
This is an attempt to generate an interlaced EIA-608 closed captions display (the NTSC "Line 21" standard, CC1) on a 525-line interlaced colour-bar picture. I don't have hardware to test, so if anyone would care to test on their NTSC setup, I'd be very curious to see if we get any captions on the TV.
Interlace: field 1's VSYNC starts with HSYNC; field 2's starts half way through a line (cycle 43), giving 262.5 + 262.5 lines. The caption data is on field 1 at line 21; field 2's line 284 (525-relative numbering) carries nulls.
The caption waveform can't sit where the standard puts it. The 2600 can only show pixels from about 14.5 µs to 59 µs after HSYNC; standard Line 21 runs from 10.5 µs to about 62 µs. The waveform is moved to about 3 µs early so the last bit fits, which means only about 3.5 of the 7 run-in cycles are visible. A strict decoder may reject it.
Emulators don't decode captions, so the real test is a Harmony cart on a TV with captions turned on.
