Reverse-Engineered Technical Manual
Refer to the latest attachments in this thread.
#1
From now on updates will be delivered via an attachment. Always grab the most recent!
NOTE: This information is "known bad" -- that is, it's a reflection of the data available for the reverse engineering effort. Essentially the information is only as good as the data -- and almost certainly the chip behaves differently.  We see *similar* results through the emulation, but the real chip function is frustratingly out of reach at this stage.
We need more recordings, more probes, and some way of getting cleaner data.
Having posted that disclaimer, what we have is "good". It does a decent job of reproducing the sounds of the SpeakJet chip - an analogue, as it were, that's usable.
From now on please grab the absolute-latest technical manual from...
SpeakJet Reverse Engineering - Technical Manual
Please note this supercedes earlier versions and has changed some assertions/findings.
It's a work in progress, after all
