Manual "HINT" editor
Although the fitting process was (and still is) fully automatic, I've found it prudent to manually intervene in some of the sounds -- and so we now have a "editor" that lets me draw lines and boxes over the spectra.  The idea here is that the fitting code uses these lines as guidelines (literally).  The start/end time and frequency is used from my manual setting, and the intensity is grabbed from the spectra itself, so the fades in and out are handled automatically. After a fit is made, then a comprehensive "anneal" - well actually a "CMA-ES" run is done on the solution to optimise it and minimise error.
CMA-ES is the Covariance Matrix Adaptation Evolution Strategy, a derivative-free optimiser for continuous, non-linear, non-convex problems. Nikolaus Hansen and Andreas Ostermeier developed it in the mid-1990s, and it is still one of the strongest general-purpose black-box optimisers for roughly 2 to a few hundred dimensions.
