Vox Probe 14
**AtariVox / SpeakJet emulation: VoxProbe 14, please record**
Here is the fourteenth probe ROM. VoxProbe 13's recordings went into 0.4.3 (see the release post): the Speed law above the default, the pauses, the silence before unvoiced stops, the chip reading a Slow ahead, and how nasals, liquids and stops join their neighbours. Several of those rules rest on only a handful of items, and a few things are still visibly off. VoxProbe 14 is built to check each of them across many more sounds.
It runs about 3 min 15 s. As before, I'd like it from both units if possible: the original AtariVox and the AtariVox+.
**Recording.** The same setup as VoxProbe 7 to 13: 48 kHz, 16-bit, no input processing (no noise reduction, no AGC). The probe starts with 1.5 s of silence and then a 1000 Hz tone; set the level so that tone sits at about -10 dBFS and nothing clips. Start recording, press FIRE (or RESET) to start the sequence, and leave it running until the closing tone and silence and the slowed effects after it. Each section is announced by touch-tone digits, and every item starts from a reset. The title screen reads VOXPROBE 14 B1; please say which build you recorded.
**What it tests**
1  reference           1.5 s of silence, the 1000 Hz tone
 2  the Speed step      AW and IYUW alone at Speed 113, 114, 115, 116, 117 and 120; AW P2 AW at 113, 115, 117:
                        where exactly the chip steps down above the default
 3  consonants above    DH FF NE TT GO between AWs at Speed 114, 118, 127; NE GO OW at 116, 118, 122: do
    Speed 114           consonants shrink with Speed (Man Goes Down says no at 118, one item says yes at 127)
 4  Slow on unvoiced    TT KO PO between AWs, plain, slowed, and slowed before a pause; Slow TT and Slow KO
    stops               alone: the chip lengthens the sound before a slowed stop, not the stop
 5  hisses              TH and SE between vowels, plain and slowed; SE AW, SH IY, FF OW, TH UW, SE UX
 6  hisses alone        SE, TH, Slow SE, Slow TH
 7  velars              GE GO KE KO before IY EH AW OW UW: GE glides into the vowel; GO IY is short
 8  joins, BO           AW IH, AW IH AW, IY AW IY, IH AW IH, AY IY, AY IY AW; BO and BE before AY EH IH AW
 9  copies              SE SE, SE SE SE, Slow SE SE, SE Slow SE, SH SH; UX UX UX with and without a Pitch
                        between; Man Goes Down phrase 4's slowed IYUW into its double SE
10  nasals before       NE NO MM NGE before GO DO BO KO, each into AW; NE GE, NGO GO, NE AW; NE Slow GO,
    stops               NE Fast GO; NE GO at Speed 108
11  RR and IY           RR and IY alone; AW RR, TH RR AW, RR AW; DO IY, BE IY, GO IY, IY P2 AW
12  slowed glides       Slow IYUW Slow AW; Slow AYWW and Slow OWWW into Slow SE; Slow IYUW Slow SE at Speed
                        100 and 127
13  M2                  M2, and M2 at Pitch 150
14  reference again     the 1000 Hz tone, 1.5 s of silence
15  slowed effects      R5 R8 R9 C8 C9 B0 at Speed 0 (last: slowed, an effect can sound like a section marker)
Two things learned from VoxProbe 13 shaped the layout. A hiss after a vowel sits under the recording's hum, so every hiss item ends on a vowel and can be timed. And every join is followed by a vowel, so both sides of it have a clear edge.
ROM: vox_probe14.bin (4 KB, NTSC). Thanks again for the recordings; everything the emulation knows about the chip has come from them.
SpiceWare
