v0.5.7 graphs
Release 0.5.7 now comes with new graphs, showing the state of each emulated sound.
                      n   mean X                change on   median X              over 1.0
                          0.4.3  0.5.6  0.5.7   0.4.3  0.5.6   0.4.3  0.5.6  0.5.7     0.4.3  0.5.6  0.5.7
allophones           72    1.20   0.95   0.92    -23 %    -3 %    1.13   0.87   0.85       46     25     25
sound effects        55    1.75   1.22   1.15    -34 %    -5 %    1.75   1.22   1.12       52     42     39
all sounds          127    1.44   1.07   1.02    -29 %    -4 %    1.29   1.02   1.00       98     67     64
connected speech (44 phrase items on both units, lower is closer)
one AtariVox against the other     143.9
0.5.6                              235.7
0.5.7                              236.3
The median sound is now exactly as close to the chip as a second AtariVox recording would be.
The new pictures
Every sound has a new comparison picture: the chip, the emulation, where they differ, the whole-sound spectrum, and the sound's score at every release since 0.3.0.
Reading the pictures
The example is 222 B2.
The recordings. Each sound was recorded four times from two real AtariVoxes: two takes from each unit, across two sessions. Real hardware never repeats itself exactly, so a recording only counts as wrong where it falls outside what those four takes do between them. All the comparisons below are built on that idea.
Top left: the chip (unit A). A spectrogram of one real recording. Time runs left to right in milliseconds, frequency from 50 Hz up to 8 kHz on a log scale, and darker means louder. It's there as the reference picture of what the sound looks like.
Middle left: the emulation. The same spectrogram of our output, on the same time and frequency axes, placed in time the way the score places it. The title gives the score, X, where 1.0 means "as close to the chip as one real recording is to another". Below 1.0, ours is closer to the chip than a second take would be. The parts that make up X follow it in the title.
Bottom left: the excess. This is the most useful panel. At every point in time and frequency (smoothed to about 10 ms and a third of an octave) it compares ours with all four real takes.
White: ours sits inside the range the four recordings cover. No real AtariVox could be told apart from it there.
Red: ours is louder than every one of the four takes.
Blue: ours is quieter than every one of the four takes.
Scale: ±10 dB.
Title: the share of the picture that's outside, and XE, its score (1.0 is again a typical real take).
The difference between two units, or two sessions, is already in the white. So any colour is something the chip simply doesn't do. On B2, the red at 300-800 Hz between 40 and 100 ms is ours sounding a low band the chip doesn't. The scattered blue along the 2-4 kHz lines is ours slightly short where the chip's lines are brightest.
The idea for this panel came from a user, who asked for "the difference from the difference": not ours minus one recording, but ours set against how much the recordings differ among themselves.
Top right: the whole-sound spectrum. The level of every frequency over the whole sound, in dB under its loudest point.
Blue lines: each of the four real takes, with the band between them shaded.
Orange: ours.
Grey dotted: the recording's background noise.
Grey shading: frequencies where the chip is less than 15 dB above that background, so nobody can say what the chip does there.
The takes are drawn one by one rather than averaged on purpose. The two units' clocks differ by about 0.3 %, so their harmonics sit a few Hz apart. Averaging fills in the gaps between harmonics and makes any single recording, ours included, look wrong.
Bottom right: the history. This sound's X at every release of the library, from 0.3.0 to now, each release rebuilt from its own source and scored on today's measure. Releases are placed by their date and labelled by version number. The scale is zoomed to the sound's own range so the changes show, so read the numbers on the points rather than judging by the slope, and compare one picture with another the same way. The dashed line is 1.0, with the area under it shaded faint green and the area over it faint red. B2 has come down from 2.47 at 0.3.0 to 1.47 now. Its biggest steps were 0.4.1 (2.45 to 2.19) and 0.5.6 (1.88 to 1.63).
The line along the bottom: the scorer's own notes on the sound, such as lines that move where the chip's are steady, or an onset that's late.
151-160
161-170
171-180
181-190
191-200
201-210
211-220
221-230
231-240
241-254
