v0.27.0
JetSetIlly
https://github.com/JetSetIlly/Gopher2600/releases/tag/v0.27.0
This new release is the first to show a version number to the user. This was asked for by Spiceware and makes a lot of sense. There was always a way to get the git revision but that's an awkward way to do things. The version number is now shown in the title bar of the window.
I've added the UA bank switching scheme. Stella was used as a reference for the hotspot addresses and fingerprint bytes.
I've added a Cycle quantum state to the debugger. This is in addition to the pre-existing Instruction and Clock quantums. The quantum state affects how the user interacts with the emulation through the debugger. For example, stepping forward will move forward either one instruction, one CPU cycle or one TIA colour clock, depending on the quantum state. The state is changed via the Control window (or by the QUANTUM command in the terminal). The button next to the step command shows the three options when pressed.
For most development purposes the instruction quantum is all you need but occasionally it's useful to understand what's happening on the data/address buses or the precise state of the TIA whilst it is in the middle of an instruction cycle.
I've also overhauled the CRT effects. The 'noise' effect is gone and is now part of the 'interference' effect. This new combination is better IMO. There is also a 'flicker' effect that causes a subtle flutter of brightness on the screen. I've also improved the bevel effect.
@jetsetilly.bsky.social
