Display kernel for 5 Card stud Poker
Al_Nafuur
Quote from: Andrew Davie on 16 Feb 2024, 02:40 AM
Quote from: Al_Nafuur on 14 Feb 2024, 05:56 AMHere is a Paintshoped! version how it might look like if we manage to use the playfield as background for the cards and add player1 to the status info:
I'm watching with interest!  Is there are reason the fonts and cards are so vertically squished?  They would look much better, IMHO, if they were at least double the height.
As far as I understand the game, we need to squeeze up to 8 players on the screen.
Quote from: Al_Nafuur on 16 Feb 2024, 03:39 AMAs far as I understand the game, we need to squeeze up to 8 players on the screen.
You may need to be able to see the cards of 8 players. But you don't necesarily need to see them all at the same time. For example, if you allowed up/down scrolling as if you were looking around the table, then you could have any number of players.  Just show the 4 or 5 players that you can fit on the screen, with some indication there are more above or below.  Me, I'd rather have larger prettier graphics and the "inconvenience" of scrolling, than barely legible cards.
Another thing - you could always keep your cards visible (bottom non-scrolling section), and the upper section scrolls bewteen the other players.
Another option: have two sizes of cards; yours are always large, and the currently active player is always large. The other players are small-size, like you have now.
Al_Nafuur
Quote from: Andrew Davie on 16 Feb 2024, 03:54 AM
Quote from: Andrew Davie on 16 Feb 2024, 03:56 AMAnother option: have two sizes of cards; yours are always large, and the currently active player is always large. The other players are small-size, like you have now.
Very good ideas!
But this is my first 2600 kernel, so I am not sure I can add this.
Currently I am changing the memory layout, so less RIOT RAM is needed to store the 40 cards of the 8 players. My current layout only works for 5 players.
alex_79
#19
What about arranging the cards diagonally to reduce the number of sprites on the same line?
Something like this:
Use a single copy of P0,P1 and PF1. Each following card always requires a movement to the left, so you could use an early HMOVE and avoid the black bars.
Al_Nafuur
Quote from: alex_79 on 16 Feb 2024, 08:23 AMWhat about arranging the cards diagonally to reduce the number of sprites on the same line?
nice!
But it will need more rows per poker player, so would have to use multiple pages.
alex_79
Quote from: Al_Nafuur on 16 Feb 2024, 09:21 AMBut it will need more rows per poker player, so would have to use multiple pages.
Yes, scrolling would still be needed in case of many players.
Another mockup:
By setting the sprites to "2 copies, med", you could fit 4 players per row, albeit a bit cramped...
The uneven spacing is to have a repeated playfield, without mid-line writes to it.
If you only need 8 player max, only two rows are needed, and you could stretch them vertically to make them nicer, with still room for status lines below them.
Al_Nafuur
Here the code of the new version that uses only 59 bytes (+ 3 temps) for 8 players. The previous version used nearly all ZP-RAM for 5 players.
        processor 6502
        include "vcs.h"
        include "macro.h"
LEFT_PLAYERS_XPOS = 18
RIGHT_PLAYERS_XPOS = 66
        org  $f000
cards                   equ $80 ; 5x8 = 40 bytes !
player_counter          equ $A8 ; 1 byte
current_player          equ $A9 ; 12 byte
current_color           equ $B5 ; 6 bytes
                                ; $F1 to stack free
temp1                   equ $F1
temp2                   equ $F2
temp3                   equ $F3
; Bitmap pattern for cards
CARD_ACE_CROSS
        .byte $00,$A7,$A2,$E2,$A7,$42
CARD_ACE_PIK
        .byte $00,$A7,$A2,$E7,$A7,$42
CARD_ACE_HEART
        .byte $00,$A0,$A2,$E7,$A7,$45
CARD_ACE_CARO
        .byte $00,$A0,$A2,$E7,$A7,$42
CARD_KING_CROSS
        .byte $00,$A7,$A2,$C2,$A7,$A2
CARD_KING_PIK
        .byte $00,$A7,$A2,$C7,$A7,$A2
CARD_KING_HEART
        .byte $00,$A0,$A2,$C7,$A7,$A5
CARD_KING_CARO
        .byte $00,$A0,$A2,$C7,$A7,$A2
CARD_QUEEN_CROSS
        .byte $00,$67,$A2,$A2,$A7,$42
CARD_QUEEN_PIK
        .byte $00,$67,$A2,$A7,$A7,$42
CARD_QUEEN_HEART
        .byte $00,$60,$A2,$A7,$A7,$45
CARD_QUEEN_CARO
        .byte $00,$60,$A2,$A7,$A7,$42
CARD_JACK_CROSS
        .byte $00,$47,$A2,$22,$27,$22
CARD_JACK_PIK
        .byte $00,$47,$A2,$27,$27,$22
CARD_JACK_HEART
        .byte $00,$40,$A2,$27,$27,$25
CARD_JACK_CARO
        .byte $00,$40,$A2,$27,$27,$22
CARD_10_CROSS
        .byte $00,$B7,$B2,$B2,$B7,$B2
CARD_10_PIK
        .byte $00,$B7,$B2,$B7,$B7,$B2
CARD_10_HEART
        .byte $00,$B0,$B2,$B7,$B7,$B5
CARD_10_CARO
        .byte $00,$B0,$B2,$B7,$B7,$B2
CARD_9_CROSS
        .byte $00,$E7,$22,$E2,$A7,$E2
CARD_9_PIK
        .byte $00,$E7,$22,$E7,$A7,$E2
CARD_9_HEART
        .byte $00,$E0,$22,$E7,$A7,$E5
CARD_9_CARO
        .byte $00,$E0,$22,$E7,$A7,$E2
CARD_8_CROSS
        .byte $00,$E7,$A2,$E2,$A7,$E2
CARD_8_PIK
        .byte $00,$E7,$A2,$E7,$A7,$E2
CARD_8_HEART
        .byte $00,$E0,$A2,$E7,$A7,$E5
CARD_8_CARO
        .byte $00,$E0,$A2,$E7,$A7,$E2
CARD_7_CROSS
        .byte $00,$27,$22,$25,$27,$E2
CARD_7_PIK
        .byte $00,$27,$22,$27,$27,$E2
CARD_7_HEART
        .byte $00,$20,$22,$27,$27,$E5
CARD_7_CARO
        .byte $00,$20,$22,$27,$27,$E2
CARD_6_CROSS
        .byte $00,$E7,$A2,$E5,$87,$E2
CARD_6_PIK
        .byte $00,$E7,$A2,$E7,$87,$E2
CARD_6_HEART
        .byte $00,$E0,$A2,$E7,$87,$E5
CARD_6_CARO
        .byte $00,$E0,$A2,$E7,$87,$E2
CARD_5_CROSS
        .byte $00,$E7,$22,$E5,$87,$E2
CARD_5_PIK
        .byte $00,$E7,$22,$E7,$87,$E2
CARD_5_HEART
        .byte $00,$E0,$22,$E7,$87,$E5
CARD_5_CARO
        .byte $00,$E0,$22,$E7,$87,$E2
CARD_4_CROSS
        .byte $00,$27,$22,$E5,$A7,$A2
CARD_4_PIK
        .byte $00,$27,$22,$E7,$A7,$A2
CARD_4_HEART
        .byte $00,$20,$22,$E7,$A7,$A5
CARD_4_CARO
        .byte $00,$20,$22,$E7,$A7,$A2
CARD_3_CROSS
        .byte $00,$E2,$22,$65,$27,$E2
CARD_3_PIK
        .byte $00,$E2,$22,$67,$27,$E2
CARD_3_HEART
        .byte $00,$E0,$22,$67,$27,$E5
CARD_3_CARO
        .byte $00,$E0,$22,$67,$27,$E2
CARD_2_CROSS
        .byte $00,$E2,$82,$E5,$27,$E2
CARD_2_PIK
        .byte $00,$E2,$82,$E7,$27,$E2
CARD_2_HEART
        .byte $00,$E0,$82,$E7,$27,$E5
CARD_2_CARO
        .byte $00,$E0,$82,$E7,$27,$E2
CARD_FACE_DOWN
        .byte $00,$FF,$AB,$D5,$AB,$FF
        .byte $00,$55,$AA,$55,$AA,$55
CARD_FREE
        .byte $00,$FF,$00,$00,$00,$00
CARD_BLANK
        .byte $00,$00,$00,$00,$00,$00
CARD_1
        .byte $00,$22,$22,$22,$22,$22
CARD_2
        .byte $00,$EE,$88,$EE,$22,$EE
CARD_3
        .byte $00,$EE,$22,$66,$22,$EE
CARD_4
        .byte $00,$22,$22,$EE,$AA,$AA
CARD_5
        .byte $00,$EE,$22,$EE,$88,$EE
CARD_6
        .byte $00,$EE,$AA,$EE,$88,$EE
CARD_7
        .byte $00,$22,$22,$22,$22,$EE
CARD_8
        .byte $00,$EE,$AA,$EE,$AA,$EE
CARD_9
        .byte $00,$EE,$22,$EE,$AA,$EE
card_pointers_hi
        .byte >CARD_ACE_CROSS
        .byte >CARD_ACE_PIK
        .byte >CARD_ACE_HEART
        .byte >CARD_ACE_CARO
        .byte >CARD_KING_CROSS
        .byte >CARD_KING_PIK
        .byte >CARD_KING_HEART
        .byte >CARD_KING_CARO
        .byte >CARD_QUEEN_CROSS
        .byte >CARD_QUEEN_PIK
        .byte >CARD_QUEEN_HEART
        .byte >CARD_QUEEN_CARO
        .byte >CARD_JACK_CROSS
        .byte >CARD_JACK_PIK
        .byte >CARD_JACK_HEART
        .byte >CARD_JACK_CARO
        .byte >CARD_10_CROSS
        .byte >CARD_10_PIK
        .byte >CARD_10_HEART
        .byte >CARD_10_CARO
        .byte >CARD_9_CROSS
        .byte >CARD_9_PIK
        .byte >CARD_9_HEART
        .byte >CARD_9_CARO
        .byte >CARD_8_CROSS
        .byte >CARD_8_PIK
        .byte >CARD_8_HEART
        .byte >CARD_8_CARO
        .byte >CARD_7_CROSS
        .byte >CARD_7_PIK
        .byte >CARD_7_HEART
        .byte >CARD_7_CARO
        .byte >CARD_6_CROSS
        .byte >CARD_6_PIK
        .byte >CARD_6_HEART
        .byte >CARD_6_CARO
        .byte >CARD_5_CROSS
        .byte >CARD_5_PIK
        .byte >CARD_5_HEART
        .byte >CARD_5_CARO
        .byte >CARD_4_CROSS
        .byte >CARD_4_PIK
        .byte >CARD_4_HEART
        .byte >CARD_4_CARO
        .byte >CARD_3_CROSS
        .byte >CARD_3_PIK
        .byte >CARD_3_HEART
        .byte >CARD_3_CARO
        .byte >CARD_2_CROSS
        .byte >CARD_2_PIK
        .byte >CARD_2_HEART
        .byte >CARD_2_CARO
        .byte >CARD_FACE_DOWN
        .byte >CARD_BLANK
        .byte >CARD_1
        .byte >CARD_2
        .byte >CARD_3
        .byte >CARD_4
        .byte >CARD_5
        .byte >CARD_6
        .byte >CARD_7
        .byte >CARD_8
        .byte >CARD_9
card_pointers_lo
        .byte <CARD_ACE_CROSS
        .byte <CARD_ACE_PIK
        .byte <CARD_ACE_HEART
        .byte <CARD_ACE_CARO
        .byte <CARD_KING_CROSS
        .byte <CARD_KING_PIK
        .byte <CARD_KING_HEART
        .byte <CARD_KING_CARO
        .byte <CARD_QUEEN_CROSS
        .byte <CARD_QUEEN_PIK
        .byte <CARD_QUEEN_HEART
        .byte <CARD_QUEEN_CARO
        .byte <CARD_JACK_CROSS
        .byte <CARD_JACK_PIK
        .byte <CARD_JACK_HEART
        .byte <CARD_JACK_CARO
        .byte <CARD_10_CROSS
        .byte <CARD_10_PIK
        .byte <CARD_10_HEART
        .byte <CARD_10_CARO
        .byte <CARD_9_CROSS
        .byte <CARD_9_PIK
        .byte <CARD_9_HEART
        .byte <CARD_9_CARO
        .byte <CARD_8_CROSS
        .byte <CARD_8_PIK
        .byte <CARD_8_HEART
        .byte <CARD_8_CARO
        .byte <CARD_7_CROSS
        .byte <CARD_7_PIK
        .byte <CARD_7_HEART
        .byte <CARD_7_CARO
        .byte <CARD_6_CROSS
        .byte <CARD_6_PIK
        .byte <CARD_6_HEART
        .byte <CARD_6_CARO
        .byte <CARD_5_CROSS
        .byte <CARD_5_PIK
        .byte <CARD_5_HEART
        .byte <CARD_5_CARO
        .byte <CARD_4_CROSS
        .byte <CARD_4_PIK
        .byte <CARD_4_HEART
        .byte <CARD_4_CARO
        .byte <CARD_3_CROSS
        .byte <CARD_3_PIK
        .byte <CARD_3_HEART
        .byte <CARD_3_CARO
        .byte <CARD_2_CROSS
        .byte <CARD_2_PIK
        .byte <CARD_2_HEART
        .byte <CARD_2_CARO
        .byte <CARD_FACE_DOWN
        .byte <CARD_BLANK
        .byte <CARD_1
        .byte <CARD_2
        .byte <CARD_3
        .byte <CARD_4
        .byte <CARD_5
        .byte <CARD_6
        .byte <CARD_7
        .byte <CARD_8
        .byte <CARD_9
; Initialize and set initial offsets of objects.
start        CLEAN_START
        ldx #$00
        stx COLUBK                ; set the background color
        inx
        lda #RIGHT_PLAYERS_XPOS+8
        jsr SetHorizPos           ; set player 1 horiz. pos
        lda #6
        sta NUSIZ0                ; make player0 3 copies wide
        lda #0
        sta NUSIZ1                ; make player1 single copy
        lda #%1
        sta CTRLPF                ; set playfield mirror (move after stx COLUBK and inx ?)
        lda #$C2
        sta COLUPF
        lda #$C0
        sta PF0
        lda #$FF
        sta PF1
        sta PF2
;        sta GRP1
        lda #$0E
        sta COLUP1
; Load some valid cards into RAM (PlusROM load later)
        ldx #39
fill_cards
        txa
        sta cards,x
        dex
        bpl fill_cards
        lda #52
        sta cards
        sta cards+8
        sta cards+12
        sta cards+20
        ldy #54
        sty cards+2
        iny
        sty cards+6
        iny
        sty cards+14
        iny
        sty cards+18
; end of "loading"
        nop         ; padding so skip_pause in kernel don't cross page
; We've technically generated an invalid frame because
; these operations have generated superfluous WSYNCs.
; But it's just at the beginning of our program, so whatever.
; Next frame loop
nextframe
        VERTICAL_SYNC
; 36 lines of VBLANK
        ldx #36
lvblank
        sta WSYNC
        dex
        bne lvblank
; Draw 192 scanlines
draw_a_player
        ldy #RIGHT_PLAYERS_XPOS
        lda player_counter
        and #1
        bne set_player_xpos
        ldy #LEFT_PLAYERS_XPOS
set_player_xpos
        tya
        jsr SetHorizPos        ; set player 0 horiz. pos
        ldy #5                 ; y is sprite data index
        sta WSYNC
        sta WSYNC
lvscan1
        sta WSYNC              ; wait for next scanline
        lda current_color
        sta COLUP0
        lda (current_player),y
        sta GRP0               ; set sprite 0 pixels
        lda player_counter
        and #1
        beq skip_pause
        SLEEP 16
skip_pause
        lda (current_player+2),y
        ldx current_color+1
        sta GRP0
        stx COLUP0
        lda (current_player+4),y
        ldx current_color+2
        sta GRP0
        stx COLUP0
        dey
        bne lvscan1            ; repeat next scanline until finished
        sty GRP0
        ldx #4
        jsr spacer
lvscan2
        lda current_color+3
        sta COLUP0
        lda (current_player+6),y
        lda player_counter
        and #1
        beq skip_pause2
        SLEEP 16
skip_pause2
        lda (current_player+8),y
        ldx current_color+4
        sta GRP0
        stx COLUP0
        lda (current_player+10),y
        ldx current_color+5
        sta GRP0
        stx COLUP0
        dey
        bne lvscan2            ; repeat next scanline until finished
        sta WSYNC
        sty GRP0
        ldx #0
        inc player_counter
        lda player_counter
        cmp #4                 ; a = player_counter
        bpl endOfplayers
        jmp draw_a_player
endOfplayers
        stx player_counter     ; x = 0 !
        ldx #77
footer
        dex
        bne footer
; 30 lines of overscan
        ldx #25
lvover
        sta WSYNC
        dex
        bne lvover
        jmp nextframe
; Subroutines !!
spacer
        dex
        bne spacer
        rts
SetHorizPos
;call this function with A == horizontal position (0-159)
;and X == the object to be positioned (0=P0, 1=P1, 2=M0, etc.)
;if you do not wish to write to P1 during this function, make
;sure Y==0 before you call it.  This function will change Y, and A
;will be the value put into HMxx when returned.
;Call this function with at least 11 cycles left in the scanline
;(jsr + sec + sta WSYNC = 11); it will return 9 cycles
;into the second scanline
        sec
        sta WSYNC                       ;begin line 1
        sta.w HMCLR                     ;+4         4
DivideBy15Loop
        sbc #15
        bcs DivideBy15Loop              ;+4/5        8/13.../58
        tay                             ;+2        10/15/...60
        lda FineAdjustTableEnd,Y        ;+5        15/20/...65
                                        ;        15
        sta HMP0,X                      ;+4        19/24/...69
        sta RESP0,X                     ;+4        23/28/33/38/43/48/53/58/63/68/73
        sta WSYNC                       ;+3         0        begin line 2
        sta HMOVE                       ;+3
; adding the copyroutine for the card pointer and colors here
        ldy player_counter
        ldx multiply_by_6_table,y
        ldy #11
copy_routine
        dex
        stx temp1
        lda cards,x
        sta temp2
        cmp #52
        beq bluecard
        bmi nowhitecard
        ldx #$0E
        jmp endCardColor
bluecard
        ldx #$80
        jmp endCardColor
nowhitecard
        and #2
        bne redcard
        ldx #0
        jmp endCardColor
redcard
        ldx #$40
endCardColor
        tya
        clc
        ror
        sta temp3
        txa
        ldx temp3
        sta current_color,x     ; y/2 !!
        ldx temp2
        lda card_pointers_hi,x
        sta current_player,y
        dey
        lda card_pointers_lo,x
        ldx temp1
        dey
        bpl copy_routine
        rts
; test
        ldy player_counter
        ldy #5
copy_color_routine
        dex
        stx temp1
        lda cards,x
        cmp #52
        beq bluecard2
        bmi nowhitecard2
        ldx #$0E
        jmp endCardColor2
bluecard2
        ldx #$80
        jmp endCardColor2
nowhitecard2
        and #2
        bne redcard
        ldx #0
        jmp endCardColor2
redcard2
        ldx #$40
endCardColor2
        tya
        clc
        ror
        sta temp3
        txa
        ldx temp3
        ldx temp1
        dey
        bpl copy_color_routine
multiply_by_6_table     ; max 8 player !
        .byte 6,12,18,24,30,36,42,48
        .byte 5,11,17,23,29,35,41,47
FineAdjustTableBegin
        .byte %01100000                ;left 6
        .byte %01010000
        .byte %01000000
        .byte %00110000
        .byte %00100000
        .byte %00010000
        .byte %00000000                ;left 0
        .byte %11110000
        .byte %11100000
        .byte %11010000
        .byte %11000000
        .byte %10110000
        .byte %10100000
        .byte %10010000
        .byte %10000000                ;right 8
FineAdjustTableEnd        =        (FineAdjustTableBegin - 241)
; Epilogue
        org $fffc
        .word start
        .word start
Al_Nafuur
Quote from: alex_79 on 16 Feb 2024, 08:43 PM
Another mockup:
Yes I thought about using your suggestion with both sprites. But I am not sure how to make the info line. Also I am not sure how to hide the playfield backgrounds for players that have folded
Al_Nafuur
Quote from: thom.cherryhomes on 16 Feb 2024, 02:15 AMHey, awesome! I didn't know this forum existed! :)
I'm the firmware engineer for FujiNet. :)
I'll be watching here. @Jeff Piepmeier is getting our device up (it just booted a 2K ROM yesterday), and as this comes together, i'll be jumping in to help. :)
-Thom
@thom.cherryhomes do you have a screenshot from the 8bit version with 8 players?
Al_Nafuur
Al_Nafuur
I managed to add sprite1 to the player info, so we can display up to 9999 chips per player.
With 8 players on the screen we are 9 scanlines over the NTSC standard (262 scanlines) and we still have to display the pot.
So we use either several pages, or a completely different kernel (like the one proposed by alex_79)
Al_Nafuur
HMOVE bars and heights are still not correct. But it looks like I cannot copy/unpack the next row and move the players + playfield in two scanlines.
Al_Nafuur
No clean code below this line:
    processor 6502
    include "vcs.h"
    include "macro.h"
LEFT_PLAYERS_XPOS = 28
RIGHT_PLAYERS_XPOS = 108
    org  $f000
player_data             equ $80 ; 7x8 = 56 bytes !
row_counter          equ $B8 ; 1 byte
current_row          equ $B9 ; 8 byte
current_color           equ $C7 ; 4 bytes
temp1                   equ $F1
temp2                   equ $F2
temp3                   equ $F3
CARD_ACE_CROSS
    .byte $A7,$A2,$E2,$A7,$42
CARD_ACE_PIK
    .byte $A7,$A2,$E7,$A7,$42
CARD_ACE_HEART
    .byte $A0,$A2,$E7,$A7,$45
CARD_ACE_CARO
    .byte $A0,$A2,$E7,$A7,$42
CARD_KING_CROSS
    .byte $A7,$A2,$C2,$A7,$A2
CARD_KING_PIK
    .byte $A7,$A2,$C7,$A7,$A2
CARD_KING_HEART
    .byte $A0,$A2,$C7,$A7,$A5
CARD_KING_CARO
    .byte $A0,$A2,$C7,$A7,$A2
CARD_QUEEN_CROSS
    .byte $67,$A2,$A2,$A7,$42
CARD_QUEEN_PIK
    .byte $67,$A2,$A7,$A7,$42
CARD_QUEEN_HEART
    .byte $60,$A2,$A7,$A7,$45
CARD_QUEEN_CARO
    .byte $60,$A2,$A7,$A7,$42
CARD_JACK_CROSS
    .byte $47,$A2,$22,$27,$22
CARD_JACK_PIK
    .byte $47,$A2,$27,$27,$22
CARD_JACK_HEART
    .byte $40,$A2,$27,$27,$25
CARD_JACK_CARO
    .byte $40,$A2,$27,$27,$22
CARD_10_CROSS
    .byte $B7,$B2,$B2,$B7,$B2
CARD_10_PIK
    .byte $B7,$B2,$B7,$B7,$B2
CARD_10_HEART
    .byte $B0,$B2,$B7,$B7,$B5
CARD_10_CARO
    .byte $B0,$B2,$B7,$B7,$B2
CARD_9_CROSS
    .byte $E7,$22,$E2,$A7,$E2
CARD_9_PIK
    .byte $E7,$22,$E7,$A7,$E2
CARD_9_HEART
    .byte $E0,$22,$E7,$A7,$E5
CARD_9_CARO
    .byte $E0,$22,$E7,$A7,$E2
CARD_8_CROSS
    .byte $E7,$A2,$E2,$A7,$E2
CARD_8_PIK
    .byte $E7,$A2,$E7,$A7,$E2
CARD_8_HEART
    .byte $E0,$A2,$E7,$A7,$E5
CARD_8_CARO
    .byte $E0,$A2,$E7,$A7,$E2
CARD_7_CROSS
    .byte $27,$22,$22,$27,$E2
CARD_7_PIK
    .byte $27,$22,$27,$27,$E2
CARD_7_HEART
    .byte $20,$22,$27,$27,$E5
CARD_7_CARO
    .byte $20,$22,$27,$27,$E2
CARD_6_CROSS
    .byte $E7,$A2,$E2,$87,$E2
CARD_6_PIK
    .byte $E7,$A2,$E7,$87,$E2
CARD_6_HEART
    .byte $E0,$A2,$E7,$87,$E5
CARD_6_CARO
    .byte $E0,$A2,$E7,$87,$E2
CARD_5_CROSS
    .byte $E7,$22,$E2,$87,$E2
CARD_5_PIK
    .byte $E7,$22,$E7,$87,$E2
CARD_5_HEART
    .byte $E0,$22,$E7,$87,$E5
CARD_5_CARO
    .byte $E0,$22,$E7,$87,$E2
CARD_4_CROSS
    .byte $27,$22,$E2,$A7,$A2
CARD_4_PIK
    .byte $27,$22,$E7,$A7,$A2
CARD_4_HEART
    .byte $20,$22,$E7,$A7,$A5
CARD_4_CARO
    .byte $20,$22,$E7,$A7,$A2
CARD_3_CROSS
    .byte $E7,$22,$62,$27,$E2
CARD_3_PIK
    .byte $E7,$22,$67,$27,$E2
CARD_3_HEART
    .byte $E0,$22,$67,$27,$E5
CARD_3_CARO
    .byte $E0,$22,$67,$27,$E2
CARD_2_CROSS
    .byte $E7,$82,$E2,$27,$E2
CARD_2_PIK
    .byte $E7,$82,$E7,$27,$E2
CARD_2_HEART
    .byte $E0,$82,$E7,$27,$E5
;padding to prevent page crossing in next card
    .byte $EA
CARD_2_CARO
    .byte $E0,$82,$E7,$27,$E2
CARD_FACE_DOWN
;        .byte $FF,$AB,$D5,$AB,$FF
    .byte $55,$AA,$55,$AA,$55
CARD_FREE
    .byte $FF,$00,$00,$00,$00
CARD_BLANK
CARD_0
    .byte $0E,$0A,$0A,$0A,$0E
CARD_1
    .byte $02,$02,$02,$02,$02
CARD_2
    .byte $0E,$08,$0E,$02,$0E
CARD_3
    .byte $0E,$02,$06,$02,$0E
CARD_4
    .byte $02,$02,$0E,$0A,$0A
CARD_5
    .byte $0E,$02,$0E,$08,$0E
CARD_6
    .byte $0E,$0A,$0E,$08,$0E
CARD_7
    .byte $02,$02,$02,$02,$0E
CARD_8
    .byte $0E,$0A,$0E,$0A,$0E
CARD_9
    .byte $0E,$02,$0E,$0A,$0E
CARD_10
    .byte $2E,$2A,$2A,$6A,$2E
CARD_11
    .byte $22,$22,$22,$22,$22
CARD_12
    .byte $2E,$28,$2E,$22,$2E
CARD_13
    .byte $2E,$22,$26,$22,$2E
CARD_14
    .byte $22,$22,$2E,$2A,$2A
CARD_15
    .byte $2E,$22,$2E,$28,$2E
CARD_16
    .byte $2E,$2A,$2E,$28,$2E
CARD_17
    .byte $22,$22,$22,$22,$2E
CARD_18
    .byte $2E,$2A,$2E,$2A,$2E
CARD_19
    .byte $2E,$22,$2E,$2A,$2E
CARD_20
    .byte $EE,$8A,$EA,$2A,$EE
CARD_21
    .byte $E2,$82,$E2,$22,$E2
CARD_22
    .byte $EE,$88,$EE,$22,$EE
CARD_23
    .byte $EE,$82,$E6,$22,$EE
CARD_24
    .byte $E2,$82,$EE,$2A,$EA
CARD_25
    .byte $EE,$82,$EE,$28,$EE
CARD_26
    .byte $EE,$8A,$EE,$28,$EE
CARD_27
    .byte $E2,$82,$E2,$22,$EE
CARD_28
    .byte $EE,$8A,$EE,$2A,$EE
CARD_29
    .byte $EE,$82,$EE,$2A,$EE
CARD_30
    .byte $EE,$2A,$6A,$2A,$EE
CARD_31
    .byte $E2,$22,$62,$22,$E2
CARD_32
    .byte $EE,$28,$6E,$22,$EE
CARD_33
    .byte $EE,$22,$66,$22,$EE
CARD_34
    .byte $E2,$22,$6E,$2A,$EA
CARD_35
    .byte $EE,$22,$6E,$28,$EE
CARD_36
    .byte $EE,$2A,$6E,$28,$EE
CARD_37
    .byte $E2,$22,$62,$22,$EE
CARD_38
    .byte $EE,$2A,$6E,$2A,$EE
CARD_39
    .byte $EE,$22,$6E,$2A,$EE
CARD_40
    .byte $2E,$2A,$EA,$AA,$AE
CARD_41
    .byte $22,$22,$E2,$A2,$A2
CARD_42
    .byte $2E,$28,$EE,$A2,$AE
CARD_43
    .byte $2E,$22,$E6,$A2,$AE
CARD_44
    .byte $22,$22,$EE,$AA,$AA
CARD_45
    .byte $2E,$22,$EE,$A8,$AE
CARD_46
    .byte $2E,$2A,$EE,$A8,$AE
CARD_47
    .byte $22,$22,$E2,$A2,$AE
CARD_48
    .byte $2E,$2A,$EE,$AA,$AE
CARD_49
    .byte $2E,$22,$EE,$AA,$AE
CARD_50
    .byte $EE,$2A,$EA,$8A,$EE
CARD_51
    .byte $E2,$22,$E2,$82,$E2
CARD_52
    .byte $EE,$28,$EE,$82,$EE
CARD_53
    .byte $EE,$22,$E6,$82,$EE
CARD_54
    .byte $E2,$22,$EE,$8A,$EA
CARD_55
    .byte $EE,$22,$EE,$88,$EE
CARD_56
    .byte $EE,$2A,$EE,$88,$EE
CARD_57
    .byte $E2,$22,$E2,$82,$EE
CARD_58
    .byte $EE,$2A,$EE,$8A,$EE
CARD_59
    .byte $EE,$22,$EE,$8A,$EE
CARD_60
    .byte $EE,$AA,$EA,$8A,$EE
CARD_61
    .byte $E2,$A2,$E2,$82,$E2
CARD_62
    .byte $EE,$A8,$EE,$82,$EE
CARD_63
    .byte $EE,$A2,$E6,$82,$EE
CARD_64
    .byte $E2,$A2,$EE,$8A,$EA
CARD_65
    .byte $EE,$A2,$EE,$88,$EE
CARD_66
    .byte $EE,$AA,$EE,$88,$EE
CARD_67
    .byte $E2,$A2,$E2,$82,$EE
CARD_68
    .byte $EE,$AA,$EE,$8A,$EE
CARD_69
    .byte $EE,$A2,$EE,$8A,$EE
CARD_70
    .byte $2E,$2A,$2A,$2A,$EE
CARD_71
    .byte $22,$22,$22,$22,$E2
CARD_72
    .byte $2E,$28,$2E,$22,$EE
CARD_73
    .byte $2E,$22,$26,$22,$EE
CARD_74
    .byte $22,$22,$2E,$2A,$EA
CARD_75
    .byte $2E,$22,$2E,$28,$EE
CARD_76
    .byte $2E,$2A,$2E,$28,$EE
CARD_77
    .byte $22,$22,$22,$22,$EE
CARD_78
    .byte $2E,$2A,$2E,$2A,$EE
CARD_79
    .byte $2E,$22,$2E,$2A,$EE
CARD_80
    .byte $EE,$AA,$EA,$AA,$EE
CARD_81
    .byte $E2,$A2,$E2,$A2,$E2
CARD_82
    .byte $EE,$A8,$EE,$A2,$EE
CARD_83
    .byte $EE,$A2,$E6,$A2,$EE
CARD_84
    .byte $E2,$A2,$EE,$AA,$EA
CARD_85
    .byte $EE,$A2,$EE,$A8,$EE
CARD_86
    .byte $EE,$AA,$EE,$A8,$EE
CARD_87
    .byte $E2,$A2,$E2,$A2,$EE
CARD_88
    .byte $EE,$AA,$EE,$AA,$EE
CARD_89
    .byte $EE,$A2,$EE,$AA,$EE
CARD_90
    .byte $EE,$2A,$EA,$AA,$EE
CARD_91
    .byte $E2,$22,$E2,$A2,$E2
CARD_92
    .byte $EE,$28,$EE,$A2,$EE
CARD_93
    .byte $EE,$22,$E6,$A2,$EE
CARD_94
    .byte $E2,$22,$EE,$AA,$EA
CARD_95
    .byte $EE,$22,$EE,$A8,$EE
CARD_96
    .byte $EE,$2A,$EE,$A8,$EE
CARD_97
    .byte $E2,$22,$E2,$A2,$EE
CARD_98
    .byte $EE,$2A,$EE,$AA,$EE
CARD_99
    .byte $EE,$22,$EE,$AA,$EE
CARD_00
    .byte $EE,$AA,$AA,$AA,$EE
CARD_01
    .byte $E2,$A2,$A2,$A2,$E2
CARD_02
    .byte $EE,$A8,$AE,$A2,$EE
CARD_03
    .byte $EE,$A2,$A6,$A2,$EE
CARD_04
    .byte $E2,$A2,$AE,$AA,$EA
CARD_05
    .byte $EE,$A2,$AE,$A8,$EE
CARD_06
    .byte $EE,$AA,$AE,$A8,$EE
CARD_07
    .byte $E2,$A2,$A2,$A2,$EE
CARD_08
    .byte $EE,$AA,$AE,$AA,$EE
CARD_09
    .byte $EE,$A2,$AE,$AA,$EE
card_pointers_hi
    .byte >CARD_ACE_PIK
    .byte >CARD_10_PIK
    .byte >CARD_10_CARO
    .byte >CARD_9_CROSS
    .byte >CARD_9_PIK
    .byte >CARD_9_HEART
    .byte >CARD_9_CARO
    .byte >CARD_8_CROSS
    .byte >CARD_8_PIK
    .byte >CARD_8_HEART
    .byte >CARD_8_CARO
    .byte >CARD_7_CROSS
    .byte >CARD_7_PIK
    .byte >CARD_7_HEART
    .byte >CARD_7_CARO
    .byte >CARD_6_CROSS
    .byte >CARD_6_PIK
    .byte >CARD_6_HEART
    .byte >CARD_6_CARO
    .byte >CARD_5_CROSS
    .byte >CARD_5_PIK
    .byte >CARD_5_HEART
    .byte >CARD_5_CARO
    .byte >CARD_4_CROSS
    .byte >CARD_4_PIK
    .byte >CARD_4_HEART
    .byte >CARD_4_CARO
    .byte >CARD_3_CROSS
    .byte >CARD_3_PIK
    .byte >CARD_3_HEART
    .byte >CARD_3_CARO
    .byte >CARD_2_CROSS
    .byte >CARD_2_PIK
    .byte >CARD_2_HEART
    .byte >CARD_2_CARO
    .byte >CARD_BLANK
    .byte >CARD_1
    .byte >CARD_2
    .byte >CARD_3
    .byte >CARD_4
    .byte >CARD_5
    .byte >CARD_6
    .byte >CARD_7
    .byte >CARD_8
    .byte >CARD_9
    .byte >CARD_10
    .byte >CARD_11
    .byte >CARD_12
    .byte >CARD_13
    .byte >CARD_14
    .byte >CARD_15
    .byte >CARD_16
    .byte >CARD_17
    .byte >CARD_18
    .byte >CARD_19
    .byte >CARD_20
    .byte >CARD_21
    .byte >CARD_22
    .byte >CARD_23
    .byte >CARD_24
    .byte >CARD_25
    .byte >CARD_26
    .byte >CARD_27
    .byte >CARD_28
    .byte >CARD_29
    .byte >CARD_30
    .byte >CARD_31
    .byte >CARD_32
    .byte >CARD_33
    .byte >CARD_34
    .byte >CARD_35
    .byte >CARD_36
    .byte >CARD_37
    .byte >CARD_38
    .byte >CARD_39
    .byte >CARD_40
    .byte >CARD_41
    .byte >CARD_42
    .byte >CARD_43
    .byte >CARD_44
    .byte >CARD_45
    .byte >CARD_46
    .byte >CARD_47
    .byte >CARD_48
    .byte >CARD_49
    .byte >CARD_50
    .byte >CARD_51
    .byte >CARD_52
    .byte >CARD_53
    .byte >CARD_54
    .byte >CARD_55
    .byte >CARD_56
    .byte >CARD_57
    .byte >CARD_58
    .byte >CARD_59
    .byte >CARD_60
    .byte >CARD_61
    .byte >CARD_62
    .byte >CARD_63
    .byte >CARD_64
    .byte >CARD_65
    .byte >CARD_66
    .byte >CARD_67
    .byte >CARD_68
    .byte >CARD_69
    .byte >CARD_70
    .byte >CARD_71
    .byte >CARD_72
    .byte >CARD_73
    .byte >CARD_74
    .byte >CARD_75
    .byte >CARD_76
    .byte >CARD_77
    .byte >CARD_78
    .byte >CARD_79
    .byte >CARD_80
    .byte >CARD_81
    .byte >CARD_82
    .byte >CARD_83
    .byte >CARD_84
    .byte >CARD_85
    .byte >CARD_86
    .byte >CARD_87
    .byte >CARD_88
    .byte >CARD_89
    .byte >CARD_90
    .byte >CARD_91
    .byte >CARD_92
    .byte >CARD_93
    .byte >CARD_94
    .byte >CARD_95
    .byte >CARD_96
    .byte >CARD_97
    .byte >CARD_98
    .byte >CARD_99
    .byte >CARD_01
    .byte >CARD_02
    .byte >CARD_03
    .byte >CARD_04
    .byte >CARD_05
    .byte >CARD_06
    .byte >CARD_07
    .byte >CARD_08
    .byte >CARD_09
card_pointers_lo
    .byte <CARD_ACE_PIK
    .byte <CARD_10_PIK
    .byte <CARD_10_CARO
    .byte <CARD_9_CROSS
    .byte <CARD_9_PIK
    .byte <CARD_9_HEART
    .byte <CARD_9_CARO
    .byte <CARD_8_CROSS
    .byte <CARD_8_PIK
    .byte <CARD_8_HEART
    .byte <CARD_8_CARO
    .byte <CARD_7_CROSS
    .byte <CARD_7_PIK
    .byte <CARD_7_HEART
    .byte <CARD_7_CARO
    .byte <CARD_6_CROSS
    .byte <CARD_6_PIK
    .byte <CARD_6_HEART
    .byte <CARD_6_CARO
    .byte <CARD_5_CROSS
    .byte <CARD_5_PIK
    .byte <CARD_5_HEART
    .byte <CARD_5_CARO
    .byte <CARD_4_CROSS
    .byte <CARD_4_PIK
    .byte <CARD_4_HEART
    .byte <CARD_4_CARO
    .byte <CARD_3_CROSS
    .byte <CARD_3_PIK
    .byte <CARD_3_HEART
    .byte <CARD_3_CARO
    .byte <CARD_2_CROSS
    .byte <CARD_2_PIK
    .byte <CARD_2_HEART
    .byte <CARD_2_CARO
    .byte <CARD_BLANK
    .byte <CARD_1
    .byte <CARD_2
    .byte <CARD_3
    .byte <CARD_4
    .byte <CARD_5
    .byte <CARD_6
    .byte <CARD_7
    .byte <CARD_8
    .byte <CARD_9
    .byte <CARD_10
    .byte <CARD_11
    .byte <CARD_12
    .byte <CARD_13
    .byte <CARD_14
    .byte <CARD_15
    .byte <CARD_16
    .byte <CARD_17
    .byte <CARD_18
    .byte <CARD_19
    .byte <CARD_20
    .byte <CARD_21
    .byte <CARD_22
    .byte <CARD_23
    .byte <CARD_24
    .byte <CARD_25
    .byte <CARD_26
    .byte <CARD_27
    .byte <CARD_28
    .byte <CARD_29
    .byte <CARD_30
    .byte <CARD_31
    .byte <CARD_32
    .byte <CARD_33
    .byte <CARD_34
    .byte <CARD_35
    .byte <CARD_36
    .byte <CARD_37
    .byte <CARD_38
    .byte <CARD_39
    .byte <CARD_40
    .byte <CARD_41
    .byte <CARD_42
    .byte <CARD_43
    .byte <CARD_44
    .byte <CARD_45
    .byte <CARD_46
    .byte <CARD_47
    .byte <CARD_48
    .byte <CARD_49
    .byte <CARD_50
    .byte <CARD_51
    .byte <CARD_52
    .byte <CARD_53
    .byte <CARD_54
    .byte <CARD_55
    .byte <CARD_56
    .byte <CARD_57
    .byte <CARD_58
    .byte <CARD_59
    .byte <CARD_60
    .byte <CARD_61
    .byte <CARD_62
    .byte <CARD_63
    .byte <CARD_64
    .byte <CARD_65
    .byte <CARD_66
    .byte <CARD_67
    .byte <CARD_68
    .byte <CARD_69
    .byte <CARD_70
    .byte <CARD_71
    .byte <CARD_72
    .byte <CARD_73
    .byte <CARD_74
    .byte <CARD_75
    .byte <CARD_76
    .byte <CARD_77
    .byte <CARD_78
    .byte <CARD_79
    .byte <CARD_80
    .byte <CARD_81
    .byte <CARD_82
    .byte <CARD_83
    .byte <CARD_84
    .byte <CARD_85
    .byte <CARD_86
    .byte <CARD_87
    .byte <CARD_88
    .byte <CARD_89
    .byte <CARD_90
    .byte <CARD_91
    .byte <CARD_92
    .byte <CARD_93
    .byte <CARD_94
    .byte <CARD_95
    .byte <CARD_96
    .byte <CARD_97
    .byte <CARD_98
    .byte <CARD_99
    .byte <CARD_01
    .byte <CARD_02
    .byte <CARD_03
    .byte <CARD_04
    .byte <CARD_05
    .byte <CARD_06
    .byte <CARD_07
    .byte <CARD_08
    .byte <CARD_09
start        CLEAN_START
    ldx #$01
    jsr SetHorizPos        ; set player 0 horiz. pos (14 scanlines)
    lda #2
    sta NUSIZ0             ; make player0 2 copies wide
;        lda #4
    sta NUSIZ1             ; make player1 2 copies wide
    lda #%0
    sta CTRLPF             ; set playfield mirror (move after stx COLUBK ?)
    lda #$C2
    sta COLUBK             ; set the background color
    lda #$00
    sta PF0
    lda #$3C
    sta PF1
    lda #$3C
    sta PF2
    lda #$0E
    sta COLUPF
; Load some valid player_data into RAM (PlusROM load later)
    ldx #51
fill_player_data
    txa
    sta player_data+3,x
    dex
    bpl fill_player_data
    lda #52
    sta player_data
    sta player_data+1
    sta player_data+2
; end of "loading"
; Next frame loop
nextframe
    VERTICAL_SYNC
    ldx #0
    lda #LEFT_PLAYERS_XPOS
    jsr SetHorizPos
    inx
    jsr SetHorizPos
    ldx #34
lvblank
    sta WSYNC
    dex
    bne lvblank
    stx row_counter
draw_a_row
;        sta WSYNC
    ldy row_counter
    ldx multiply_by_4_table,y
    ldy #7
copy_routine
    dex
    stx temp1
;        sta WSYNC
    lda player_data,x
    sta temp2
    cmp #52
    beq bluecard
    and #2
    bne redcard
    ldx #0
    jmp endCardColor
bluecard
    ldx #$80
    jmp endCardColor
redcard
    ldx #$40
endCardColor
    tya
    clc
    ror
    sta temp3
    txa
    ldx temp3
    ldx temp2
    sta current_row,y
    dey
    sta current_row,y
    ldx temp1
    dey
    bpl copy_routine
    ldy row_counter
    lda DataPF0,y
    sta PF0
    lda DataPF1,y
    sta PF1
    lda DataPF2,y
    sta PF2
    ldy #4                 ; y is sprite data index
lvscan1
    lda current_color
    sta COLUP0
    lda (current_row),y
    ldx current_color+2
    stx COLUP1
    lda (current_row+2),y
    sta GRP0
    lda current_color+1
    sta COLUP0
    lda (current_row+4),y
    sta GRP1
    lda (current_row+6),y
    ldx current_color+3
    SLEEP 8
    sta GRP1
    stx COLUP1
    dey
    bpl lvscan1            ; repeat next scanline until finished
    lda #%01000000
    sta HMP0 ; 3 21
    sta HMP1 ; 3 21
    sta HMOVE ; 3 73
; sta WSYNC
    iny
    sty GRP0
    sty GRP1
    inc row_counter
    lda row_counter
    cmp #5                 ; a = row_counter
    bpl endOfplayers
    jmp draw_a_row
endOfplayers
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    ldx row_counter
    lda DataPF0,x
    sta PF0
    lda DataPF1,x
    sta PF1
    lda DataPF2,x
    sta PF2
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    inx
    lda DataPF0,x
    sta PF0
    lda DataPF1,x
    sta PF1
    lda DataPF2,x
    sta PF2
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sta WSYNC
    sty PF0
    sty PF1
    sty PF2
    sty row_counter     ; y = 0 !
    ldx #121
footer
    dex
    bne footer
    ldx #25
lvover
    sta WSYNC
    dex
    bne lvover
    jmp nextframe
; Subroutines !!
spacer
    dex
    bne spacer
    rts
SetHorizPos
    sec
    sta.w HMCLR                     ;+4         4
DivideBy15Loop
    sbc #15
    tay                             ;+2        10/15/...60
                                    ;        15
    sta HMOVE                       ;+3
    rts
multiply_by_4_table
    .byte 4,8,12,16,20
    .byte 24,28,32,36,40
DataPF0:
    .byte $00,$00,$00,$80,$C0,$C0,$C0
DataPF1:
    .byte $3C,$7C,$FC,$F9,$F3,$E3,$C3
DataPF2:
    .byte $3C,$3E,$3F,$1F,$0F,$07,$03
    .byte %01010000
    .byte %01000000
    .byte %00110000
    .byte %00100000
    .byte %00010000
    .byte %11110000
    .byte %11100000
    .byte %11010000
    .byte %11000000
    .byte %10110000
    .byte %10100000
    .byte %10010000
; Epilogue
    org $fffc
    .word start
    .word start
Al_Nafuur
For the 4 digit status bar below the cards we would need both sprites for two players, and then flicker between the left and right two players.
Any better ideas?
