Display kernel for 5 Card stud Poker
Al_Nafuur
I am currently trying to build a display kernel for an online 5 card stud game to play on the 2600 via PlusROM function with FuijNet devices:
But I can't find the cycles to change the color and the player graphics for a player (Three copies - close)
    processor 6502
    include "vcs.h"
    include "macro.h"
    org  $f000
colors    equ $80
; Bitmap pattern for cards (will be S-RAM loaded via PlusROM)
; First byte not used (todo: optimize)
CARD_P1_0
    .byte $00,$EE,$AA,$AA,$AA,$EE
CARD_P1_1
    .byte $00,$22,$22,$22,$22,$22
CARD_P1_2
    .byte $00,$EE,$88,$EE,$22,$EE
CARD_P1_3
    .byte $00,$EE,$22,$66,$22,$EE
CARD_P1_4
    .byte $00,$AA,$AA,$EE,$22,$22
CARD_P1_5
CARD_P1_6    ; max 5 cards, so status info for this player
    .byte $00,$EE,$88,$EE,$AA,$EE
CARD_P2_0
    .byte $00,$EE,$22,$22,$22,$22
CARD_P2_1
    .byte $00,$EE,$AA,$EE,$AA,$EE
CARD_P2_2
    .byte $00,$EE,$AA,$EE,$22,$EE
; more data (120 bytes total) for all 5 players
; Initialize and set initial offsets of objects.
start    CLEAN_START
    lda #20
    ldx #0
    stx colors+1
    stx colors+3
    stx colors+6
    jsr SetHorizPos    ; set player 0 horiz. pos
    inx
    lda #68
    jsr SetHorizPos    ; set player 1 horiz. pos
    inx
    lda #3
    sta NUSIZ0    ; make missile 0 2x-wide
    inx
    lda #3
    sta NUSIZ1    ; make missile 1 4x-wide
    inx
    lda #$30
    sta CTRLPF    ; set ball 8x-wide
    sta WSYNC
    sta HMOVE
    lda #$40
    sta colors
    sta colors+2
    sta colors+4
    sta colors+5
    ldx #$C2
    stx COLUBK    ; set the background color
; We've technically generated an invalid frame because
; these operations have generated superfluous WSYNCs.
; But it's just at the beginning of our program, so whatever.
; Next frame loop
nextframe
    VERTICAL_SYNC
; 36 lines of VBLANK
    ldx #36
lvblank
    sta WSYNC
    dex
    bne lvblank
; Draw 192 scanlines
    lda #0        ; A changes every scanline
    ldx #20
header
    sta WSYNC    ; wait for next scanline
    dex
    bne header
    stx GRP1
    stx GRP0
    ldx #5        ; X is sprite data index
    SLEEP 24
lvscan
    lda colors
    sta COLUP0
    lda colors+3
    sta COLUP1
    lda CARD_P1_0,x
    sta GRP0    ; set sprite 0 pixels
    lda CARD_P1_3,x
    sta GRP1    ; set sprite 1 pixels
    ldy CARD_P1_1,x
    lda colors+1
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    sty GRP0
    sta COLUP0
    lda colors+2
    sta COLUP0
    SLEEP 4        ; change copies/color of GRP1 here.
    dex
    bne lvscan    ; repeat next scanline until finished
; Repeat code above for all 5 poker players
; Clear all colors to black before overscan
    stx COLUP0
    stx COLUP1
    stx COLUPF
    stx GRP1
    stx GRP0
    ldx #167
footer
    dex
    bne footer
; 30 lines of overscan
    ldx #25
lvover
    sta WSYNC
    dex
    bne lvover
    jmp nextframe
; SetHorizPos - Sets the horizontal position of an object.
; The X register contains the index of the desired object:
;  X=0: player 0
;  X=1: player 1
;  X=2: missile 0
;  X=3: missile 1
;  X=4: ball
; This routine does a WSYNC and HMOVE before executing,
; so whatever you do here will not take effect until you
; call the routine again or do your own WSYNC and HMOVE.
SetHorizPos
    sta WSYNC    ; start a new line
    sta HMOVE    ; apply the previous fine position(s)
    sta HMCLR    ; reset the old horizontal position(s)
    sec        ; set carry flag
DivideLoop
    sbc #15        ; subtract 15
    bcs DivideLoop    ; branch until negative
    eor #7        ; calculate fine offset
    asl
    asl
    asl
    asl
    sta RESP0,x    ; fix coarse position
    sta HMP0,x    ; set fine offset
    rts        ; return to caller
;;end
; Epilogue
    org $fffc
    .word start
    .word start
Thomas Jentzsch
Do you want to display 3 or 6 sprites per line?
If it is the latter than that would be 12 loads and stores. At 7 cycles each. Do the math. :)
Al_Nafuur
#2
Quote from: Thomas Jentzsch on 11 Feb 2024, 04:36 AMDo you want to display 3 or 6 sprites per line?
only 5 sprites are needed.
The color values are stored in ZP-RAM and loaded not indexed so 6 cycles per color change
Al_Nafuur
Maybe not all 5 cards of one player have to be on the same row
Al_Nafuur
Current attempt with two rows per player:
8bit workshop link
processor 6502
include "vcs.h"
include "macro.h"
org  $f000
colors equ $80
card_p equ $A0
CARD_ACE_CROSS
.byte $00,$AE,$A4,$E4,$AE,$44
CARD_ACE_PIK
.byte $00,$AE,$A4,$EE,$AE,$44
CARD_ACE_HEART
.byte $00,$A0,$A4,$EE,$AE,$4A
CARD_ACE_CARO
.byte $00,$A0,$A4,$EE,$AE,$44
CARD_KING_HEART
.byte $00,$A0,$A4,$CE,$AE,$AA
CARD_1
CARD_2
CARD_3
CARD_4
.byte $00,$22,$22,$EE,$AA,$AA
CARD_5
.byte $00,$EE,$22,$EE,$88,$EE
CARD_6
.byte $00,$EE,$AA,$EE,$88,$EE
CARD_7
.byte $00,$22,$22,$22,$22,$EE
CARD_8
CARD_9
.byte $00,$EE,$22,$EE,$AA,$EE
start CLEAN_START
lda #5
ldx #0
stx colors+1
stx colors+3
stx colors+6
inx
lda #68
inx
lda #6
inx
lda #6
inx
lda #$30
sta WSYNC
sta HMOVE
lda #$40
sta colors
sta colors+2
sta colors+4
        lda $0E
sta colors+5
ldx #$C2
; Load some valid pointers to the player cards
lda #<CARD_ACE_HEART
sta card_p
        lda #>CARD_ACE_HEART
sta card_p+1
        lda #<CARD_ACE_PIK
sta card_p+2
        lda #>CARD_ACE_PIK
sta card_p+3
        lda #<CARD_ACE_CARO
sta card_p+4
        lda #>CARD_ACE_CARO
sta card_p+5
        lda #<CARD_ACE_CROSS
sta card_p+6
        lda #>CARD_ACE_CROSS
sta card_p+7
        lda #<CARD_KING_HEART
sta card_p+8
        lda #>CARD_KING_HEART
sta card_p+9
        lda #<CARD_5
sta card_p+10
        lda #>CARD_5
sta card_p+11
; Next frame loop
nextframe
VERTICAL_SYNC
ldx #36
lvblank
sta WSYNC
dex
bne lvblank
ldx #20
header
dex
bne header
stx GRP1
stx GRP0
ldy #5 ; y is sprite data index
lvscan1
lda colors
sta COLUP0
lda (card_p),y
lda (card_p+2),y
ldx.w colors+1
nop
nop
sta GRP0
stx COLUP0
lda (card_p+4),y
ldx colors+2
sta GRP0
stx COLUP0
dey
bne lvscan1 ; repeat next scanline until finished
sty GRP1
sty GRP0
ldy #5 ; X is sprite data index
lvscan2
lda colors+3
sta COLUP0
lda (card_p+6),y
lda (card_p+8),y
ldx.w colors+4
nop
nop
sta GRP0
stx COLUP0
lda (card_p+10),y
ldx colors+5
sta GRP0
stx COLUP0
dey
bne lvscan2 ; repeat next scanline until finished
sty COLUP0
sty COLUP1
sty COLUPF
sty GRP1
sty GRP0
ldx #160
footer
dex
bne footer
ldx #25
lvover
sta WSYNC
dex
bne lvover
jmp nextframe
;  X=0: player 0
;  X=1: player 1
;  X=2: missile 0
;  X=3: missile 1
;  X=4: ball
SetHorizPos
DivideLoop
asl
asl
asl
asl
;;end
; Epilogue
org $fffc
.word start
.word start
Al_Nafuur
8bit workshop link
processor 6502
include "vcs.h"
include "macro.h"
LEFT_PLAYERS_XPOS = 18
RIGHT_PLAYERS_XPOS = 66
org  $f000
colors equ $80
cards_pointer equ $A0
current_player equ $C0
CARD_ACE_CROSS
.byte $00,$A7,$A2,$E2,$A7,$42
CARD_ACE_PIK
.byte $00,$A7,$A2,$E7,$A7,$42
CARD_ACE_HEART
.byte $00,$A0,$A2,$E7,$A7,$45
CARD_ACE_CARO
.byte $00,$A0,$A2,$E7,$A7,$42
CARD_KING_HEART
.byte $00,$A0,$A2,$C7,$A7,$A5
CARD_KING_CROSS
.byte $00,$A7,$A2,$C2,$A7,$A2
CARD_10_HEART
.byte $00,$B0,$B2,$B7,$B7,$B5
CARD_1
CARD_2
CARD_3
CARD_4
CARD_5
CARD_6
CARD_7
CARD_8
CARD_9
start CLEAN_START
lda #LEFT_PLAYERS_XPOS
ldx #0
stx colors+1
stx colors+3
stx colors+6
inx
lda #RIGHT_PLAYERS_XPOS+4
inx
lda #6
inx
lda #0
inx
lda #%1
sta WSYNC
sta HMOVE
lda #$40
sta colors
sta colors+2
sta colors+4
        lda $0E
sta colors+5
ldx #$00
        ldx #$C2
        stx COLUPF
        lda #$C0
        sta PF0
        lda #$ff
        sta PF1
        sta PF2
;        sta GRP1
;        sta COLUP1
lda #<CARD_10_HEART
sta cards_pointer
        lda #>CARD_10_HEART
sta cards_pointer+1
        lda #<CARD_ACE_PIK
sta cards_pointer+2
        lda #>CARD_ACE_PIK
sta cards_pointer+3
        lda #<CARD_ACE_CARO
sta cards_pointer+4
        lda #>CARD_ACE_CARO
sta cards_pointer+5
sta cards_pointer+6
sta cards_pointer+7
sta cards_pointer+8
sta cards_pointer+9
        lda #<CARD_5
sta cards_pointer+10
        lda #>CARD_5
sta cards_pointer+11
lda #<CARD_10_HEART
sta cards_pointer+12
        lda #>CARD_10_HEART
sta cards_pointer+13
        lda #<CARD_KING_CROSS
sta cards_pointer+14
        lda #>CARD_KING_CROSS
sta cards_pointer+15
        lda #<CARD_ACE_CARO
sta cards_pointer+16
        lda #>CARD_ACE_CARO
sta cards_pointer+17
sta cards_pointer+18
sta cards_pointer+19
sta cards_pointer+20
sta cards_pointer+21
        lda #<CARD_4
sta cards_pointer+22
        lda #>CARD_4
sta cards_pointer+23
; Next frame loop
nextframe
VERTICAL_SYNC
ldx #36
lvblank
sta WSYNC
dex
bne lvblank
ldx #5
jsr spacer
ldy #11
copy_routine ; 78 cycles !
lda cards_pointer,y
        sta current_player,y
        dey
        bpl copy_routine
lvscan1
lda colors
sta COLUP0
lda (current_player),y
lda (current_player+2),y
ldx.w colors+1
        SLEEP 4
sta GRP0
stx COLUP0
lda (current_player+4),y
ldx colors+2
sta GRP0
stx COLUP0
dey
sty GRP0
ldx #2
jsr spacer
lvscan2
lda colors+3
sta COLUP0
lda (current_player+6),y
lda (current_player+8),y
ldx.w colors+4
        SLEEP 4
sta GRP0
stx COLUP0
lda (current_player+10),y
ldx colors+5
sta GRP0
stx COLUP0
dey
sty GRP0
        ldx #0
        jsr SetHorizPos
ldy #11
copy_routine2 ; 78 cycles !
lda cards_pointer+12,y
        dey
        bpl copy_routine2
lvscan3
lda colors
sta COLUP0
ldx.w colors+1
        SLEEP 20
sta GRP0
stx COLUP0
ldx colors+2
sta GRP0
stx COLUP0
dey
bne lvscan3 ; repeat next scanline until finished
sty GRP0
lvscan4
lda colors+3
sta COLUP0
ldx.w colors+4
        SLEEP 20
sta GRP0
stx COLUP0
ldx colors+5
sta GRP0
stx COLUP0
dey
bne lvscan4 ; repeat next scanline until finished
sty GRP0
ldx #0
        jsr SetHorizPos
stx COLUP0
stx GRP0
ldx #145
footer
dex
bne footer
ldx #25
lvover
sta WSYNC
dex
bne lvover
jmp nextframe
; Subroutines !!
spacer
dex
bne spacer
        rts
SetHorizPos
    ;call this function with A == horizontal position (0-159)
    ;and X == the object to be positioned (0=P0, 1=P1, 2=M0, etc.)
    ;if you do not wish to write to P1 during this function, make
    ;sure Y==0 before you call it.  This function will change Y, and A
    ;will be the value put into HMxx when returned.
    ;Call this function with at least 11 cycles left in the scanline
    ;(jsr + sec + sta WSYNC = 11); it will return 9 cycles
    ;into the second scanline
    sec
    sta WSYNC                        ;begin line 1
    sta.w HMCLR                        ;+4         4
DivideBy15Loop
    sbc #15
    bcs DivideBy15Loop                        ;+4/5        8/13.../58
    tay                                ;+2        10/15/...60
    lda FineAdjustTableEnd,Y        ;+5        15/20/...65
    ;        15
    sta HMP0,X        ;+4        19/24/...69
    sta RESP0,X        ;+4        23/28/33/38/43/48/53/58/63/68/73
    sta WSYNC        ;+3         0        begin line 2
    sta HMOVE        ;+3
    rts                ;+6         9
FineAdjustTableBegin
    .byte %01100000                ;left 6
    .byte %01010000
    .byte %01000000
    .byte %00110000
    .byte %00100000
    .byte %00010000
    .byte %00000000                ;left 0
    .byte %11110000
    .byte %11100000
    .byte %11010000
    .byte %11000000
    .byte %10110000
    .byte %10100000
    .byte %10010000
    .byte %10000000                ;right 8
FineAdjustTableEnd        =        (FineAdjustTableBegin - 241)
; Epilogue
org $fffc
.word start
.word start
JetSetIlly
I like the idea of using two rows to display a single hand. However, the cards on the second row being directly below the cards on the first row is visually confusing (at least to me). Have you tried offsetting the second row so the two rows are misaligned?
@jetsetilly.bsky.social
Al_Nafuur
Quote from: JetSetIlly on 14 Feb 2024, 12:50 AMI like the idea of using two rows to display a single hand. However, the cards on the second row being directly below the cards on the first row is visually confusing (at least to me). Have you tried offsetting the second row so the two rows are misaligned?
Maybe it would be better to use white playfield as background for the cards. Currently I use the playfield as the green table and a black COLUBK to hide the HMOVE stripes
Al_Nafuur
#8
Game start:
All players have 3 cards:
5 cards
Here is a Paintshoped! version how it might look like if we manage to use the playfield as background for the cards and add player1 to the status info:
Al_Nafuur
#9
        processor 6502
        include "vcs.h"
        include "macro.h"
        org  $f000
colors                  equ $80 ; 5x6 = 30 bytes
current_color_pointer   equ $9E ; 2 bytes
cards_pointer           equ $A0 ; 5x12 = 60 bytes
player_counter          equ $DC ; 1 byte
                                ; 1 byte free
current_player_pointer  equ $DE ; 2 bytes
current_player          equ $E0 ; 12 byte
                                ; 4 bytes free
current_Color           equ $F0 ; 6 bytes
CARD_ACE_CROSS
CARD_ACE_PIK
CARD_ACE_HEART
CARD_ACE_CARO
CARD_KING_CROSS
CARD_KING_PIK
        .byte $00,$A7,$A2,$C7,$A7,$A2
CARD_KING_HEART
CARD_KING_CARO
        .byte $00,$A0,$A2,$C7,$A7,$A2
CARD_10_CROSS
        .byte $00,$B7,$B2,$B2,$B7,$B2
CARD_10_PIK
        .byte $00,$B7,$B2,$B7,$B7,$B2
CARD_10_HEART
CARD_10_CARO
        .byte $00,$B0,$B2,$B7,$B7,$B2
CARD_9_CROSS
        .byte $00,$E7,$22,$E2,$A7,$E2
CARD_9_PIK
        .byte $00,$E7,$22,$E7,$A7,$E2
CARD_9_HEART
        .byte $00,$E0,$22,$E7,$A7,$E5
CARD_9_CARO
        .byte $00,$E0,$22,$E7,$A7,$E2
CARD_1
CARD_2
CARD_3
CARD_4
CARD_5
CARD_6
CARD_7
CARD_8
CARD_9
CARD_FACE_DOWN
        .byte $00,$FF,$AB,$D5,$AB,$FF
        .byte $00,$55,$AA,$55,$AA,$55
CARD_FREE
        .byte $00,$FF,$00,$00,$00,$00
CARD_BLANK
        .byte $00,$00,$00,$00,$00,$00
start        CLEAN_START
        ldx #$00
        inx
        lda #RIGHT_PLAYERS_XPOS+8
        lda #6
        sta NUSIZ0        ; make player0 3 copies wide
        lda #0
        sta NUSIZ1        ; make player1 single copy
        lda #%1
        sta CTRLPF        ; set playfield mirror (move after stx COLUBK and inx ?)
        lda #$C2
        sta COLUPF
        lda #$C0
        sta PF0
        lda #$FF
        sta PF1
        sta PF2
;        sta GRP1
        lda #$0E
        sta COLUP1
; Load some valid pointers and colors for cards (PlusROM load later)
        lda #<CARD_FACE_DOWN
        sta cards_pointer
        lda #>CARD_FACE_DOWN
        sta cards_pointer+1
        lda #<CARD_ACE_PIK
        sta cards_pointer+2
        lda #>CARD_ACE_PIK
        sta cards_pointer+3
        lda #<CARD_5
        sta cards_pointer+4
        lda #>CARD_5
        sta cards_pointer+5
        sta cards_pointer+6
        sta cards_pointer+7
        sta cards_pointer+8
        sta cards_pointer+9
        lda #<CARD_10_CROSS
        lda #>CARD_10_CROSS
        lda #<CARD_4
        lda #>CARD_4
        lda #<CARD_ACE_CARO
        lda #>CARD_ACE_CARO
        sta cards_pointer+24
        sta cards_pointer+25
        lda #<CARD_ACE_PIK
        sta cards_pointer+26
        lda #>CARD_ACE_PIK
        sta cards_pointer+27
        lda #<CARD_1
        sta cards_pointer+28
        lda #>CARD_1
        sta cards_pointer+29
        sta cards_pointer+30
        sta cards_pointer+31
        sta cards_pointer+32
        sta cards_pointer+33
        lda #<CARD_9_CROSS
        sta cards_pointer+34
        lda #>CARD_9_CROSS
        sta cards_pointer+35
        lda #<CARD_9
        sta cards_pointer+36
        lda #>CARD_9
        sta cards_pointer+37
        lda #<CARD_ACE_CARO
        sta cards_pointer+38
        lda #>CARD_ACE_CARO
        sta cards_pointer+39
        sta cards_pointer+40
        sta cards_pointer+41
        sta cards_pointer+42
        sta cards_pointer+43
        sta cards_pointer+44
        sta cards_pointer+45
        sta cards_pointer+46
        sta cards_pointer+47
; colors (Clean start made $00 default color)
        lda #$80
        sta colors
        sta colors+8
        sta colors+12
        sta colors+20
        lda #$40
        sta colors+2
        sta colors+4
        sta colors+6
        sta colors+9
        sta colors+11
        sta colors+16
        sta colors+19
        sta colors+23
        lda $0E
        sta colors+2
        sta colors+6
        sta colors+14
        sta colors+18
; end of "loading"
        nop         ; padding so skip_pause in kernel don't cross page
; Next frame loop
nextframe
        VERTICAL_SYNC
        lda #$A0
        sta current_player_pointer
        lda #$80
        sta current_color_pointer
        ldx #36
lvblank
        sta WSYNC
        dex
        bne lvblank
draw_a_player
        ldy #RIGHT_PLAYERS_XPOS
        lda player_counter
        and #1
        bne set_player_xpos
        ldy #LEFT_PLAYERS_XPOS
set_player_xpos
        tya
        sta WSYNC
        sta WSYNC
lvscan1
        lda current_Color
        sta COLUP0
        lda player_counter
        and #1
        beq skip_pause
        SLEEP 16
skip_pause
        ldx current_Color+1
        sta GRP0
        stx COLUP0
        ldx current_Color+2
        sta GRP0
        stx COLUP0
        dey
        sty GRP0
        ldx #4
        jsr spacer
lvscan2
        lda current_Color+3
        sta COLUP0
        lda player_counter
        and #1
        beq skip_pause2
        SLEEP 16
skip_pause2
        ldx current_Color+4
        sta GRP0
        stx COLUP0
        ldx current_Color+5
        sta GRP0
        stx COLUP0
        dey
        jmp prep_next_player
        sty GRP0
return_from_prep_next_player
        cmp #4
        bmi draw_a_player
        stx player_counter     ; x = 0 !
        ldx #71
footer
        dex
        bne footer
        ldx #25
lvover
        sta WSYNC
        dex
        bne lvover
        jmp nextframe
; Subroutines !!
prep_next_player
        sta WSYNC
        sty GRP0
        ldx #0
        lda #12
        adc current_player_pointer
        lda #6
        adc current_color_pointer
        inc player_counter
        lda player_counter
        jmp return_from_prep_next_player
spacer
        dex
        bne spacer
        rts
SetHorizPos
        sec
        sta.w HMCLR                     ;+4         4
DivideBy15Loop
        sbc #15
        tay                             ;+2        10/15/...60
                                        ;        15
        sta HMOVE                       ;+3
; adding the copyroutine for the card pointer here
        ldy #11
copy_routine
        lda (current_player_pointer),y
        lda (current_color_pointer),y
        sta current_Color,y
        dey
        bpl copy_routine
        rts                ;+6         9
        .byte %01010000
        .byte %01000000
        .byte %00110000
        .byte %00100000
        .byte %00010000
        .byte %11110000
        .byte %11100000
        .byte %11010000
        .byte %11000000
        .byte %10110000
        .byte %10100000
        .byte %10010000
; Epilogue
        org $fffc
        .word start
        .word start
JetSetIlly
Out of curiosity, how much work is to connect to FujiNet?
Al_Nafuur
Quote from: JetSetIlly on 15 Feb 2024, 09:31 AMOut of curiosity, how much work is to connect to FujiNet?
I haven't really looked into it..
Most of the "work" will have to be done inside the PlusROM backend.
The lobby JSON can be loaded here: FujiNet Lobby
I think this can be easily converted to display with cd-w's text display I used in 1942 to load the HSC list:
For the communication with the game server I have to study the sources here:
https://github.com/FujiNetWIFI/servers/tree/main/5cardstud/server/mock-server
thom.cherryhomes
Hey, awesome! I didn't know this forum existed! :)
I'm the firmware engineer for FujiNet. :)
I'll be watching here. @Jeff Piepmeier is getting our device up (it just booted a 2K ROM yesterday), and as this comes together, i'll be jumping in to help. :)
-Thom
Quote from: thom.cherryhomes on 16 Feb 2024, 02:15 AMHey, awesome! I didn't know this forum existed! :)
Welcome!  Yes, it's a bit "hidden" - few people are mentioning it on AtariAge.
Quote from: Al_Nafuur on 14 Feb 2024, 05:56 AMHere is a Paintshoped! version how it might look like if we manage to use the playfield as background for the cards and add player1 to the status info:
I'm watching with interest!  Is there are reason the fonts and cards are so vertically squished?  They would look much better, IMHO, if they were at least double the height.
