Pixel aspect ratio in GIMP.
Because Atari 2600 playfield pixels are an odd aspect ratio, it's sometimes difficult to tell in your paint/editing program what things might actually look like. Fortunately, GIMP can work with non-square pixels. Here's how to set it up to do that.
There are two settings to change - firstly in Image/print size, change the horizontal dpi. I change it so that horizontal is 36 and vertical 72. You need to click the chain link to unlock the two from staying in sync. It's these dpi setting that set the relative pixel aspect size. You won't see any change, yet, though... you need to set the following as well...
Go to View/Dot for Dot and make sure that is NOT selected.  Now your image should be shown in an aspect ratio with pixels twice as wide as high. You can of course change the aspect to your desired preference.
Thomas Jentzsch
1:2 (or 36:72) is also not correct. :)
Quote from: Thomas Jentzsch on 22 Feb 2024, 03:00 AM1:2 (or 36:72) is also not correct. :)
Of course. But it's an example of how to do it. 1:2 is my personal preference. Change the aspect to your heart's desire - at least you know now how to do it :P
I should also point out that as I'm drawing mostly with iCC screens the pixel aspect of the screen is 66 pixels deep x 40 wide.  So it's 40:66 -> ~0.61 which is close-ish to 0.5... my point being there's a reason for the odd sizing. Technically I should use 44:72 but there you go.
