Download latest here!
I was unhappy with the look/feel of undo.  After some graphical changes, and a bit of UI tweaking, now I'm quite happy with it.
#16
Here's a new single-room binary. The room itself takes over 1000 moves to solve, so good luck with that. The purpose of this release is to allow testing of the 'undo'.  To trigger undo, just hold down the button until you see UNDO at the top of the screen.
The undo has a single control - button press. Each time you press the button you will remove one box push move (if any are in the undo buffer). The player will super-fast move between each of those moves, so you only need to press the button once per box-move-undo.
If there any stuck boxes (those which cannot be pushed), as far as the algorithm detecting them is capable of finding them, these will be reported as a stuck-count overlay at the top of the screen. Thus, if you push a box into a stuck position (OR, by pushing a box you cause ANOTHER box to become stuck), you will see "1 STUCK" displayed. Or, possible "2 STUCK" or even 3 or 4, depending on the configuration you have caused. If you got 1 stuck, however, then push another box into a stuck position, you will see "2 STUCK".  If you then trigger UNDO, the last box will be put back where it was, and you will now see "1 STUCK" displayed.
To exit undo at any time, just start walking around again.
#17
I've revamped the room selection screen. It's looking nice.
Right now I'm trying to get the TV "mini" representation of the room you have selected drawn in a scale such that it completely fits on the TV screen and is as large as possible. I have X working, but Y is a bit more complex, so I'm leaving that until my brain is working properly.
#18
Scaling on the TV now working pretty well, and I've put in some different rooms to test.
Here's an updated version with a few different rooms.
At the completion of a room you'll see a stats page. These stats are also overlaid over the small TV screen on the room selection page, if you have completed a room.  During normal play, you automatically progress through the rooms - but you can go back and select/replay any room. Rooms you have completed are greyed out and have the stats overlay (but are still replayable).
Kinda feels like I'm winding down now; I can't think of much to add... just polishing, optimising, and then installing about 100 rooms.
I'm not really inclined to have a password system, but I might consider AtariVox/savekey to improve the replayability.
Bomberman94
A AtariVox/savekey feature would be fantastic - what do the others think?
Quote from: Bomberman94 on 06 Aug 2025, 01:44 AMA AtariVox/savekey feature would be fantastic - what do the others think?
I think you're just about the only person following/interested!
With this version, the room selection screen now displays the PREDICTED number of moves/pushes to complete the room - whenever you hold the joystick up or down.  Left/right select the previous/next room, and of course button will start playing.
Interesting, that the first room takes 5 moves, yet the metadata associated with that room suggests 6. Hence "prediction". It's possible there are errors in other metadata.
Some more spit and polish. 20 rooms installed, graduated... kinda.
It's getting close. I wonder if anyone would be interested in paying for a binary; seems almost nobody even knows it exists. Hopefully Zeropage Homebrew will show it sometime, and actually like it :P
Just one minor bug at the moment - glitch in the score line.
Bomberman94
Looks really great - the best Sokoban that's possible on the 2600 I would say! A fine field of application (hope the term is correct) for your BD engine. I dream your engine - if makes sense/is applicable - could be used for the best computer (C64) game I can think of: Paradroid. Thomas has made some promising POC in the past but I couldn't convince him to continue...
Quote from: Bomberman94 on 08 Aug 2025, 04:55 AMLooks really great - the best Sokoban that's possible on the 2600 I would say! A fine field of application (hope the term is correct) for your BD engine. I dream your engine - if makes sense/is applicable - could be used for the best computer (C64) game I can think of: Paradroid. Thomas has made some promising POC in the past but I couldn't convince him to continue...
I just watched a Paradroid longplay on YouTube. Looks VERY do-able with the current engine.
Maybe one day, or perhaps if someone wants to write it then I'd help get them up and running with the engine.
Bomberman94
THAT would be fantastic - it would be a pleasure for me to be a tester then !
Bomberman94
Maybe Thomas Jentzsch (he's on this board as well) is interested - you both done a remarkable job with the first Boulder Dash and he did some nice drawings and scroll routine for Paradroid. Who knows...
Bomberman94
Quote from: Andrew Davie on 08 Aug 2025, 01:49 AMSome more spit and polish. 20 rooms installed, graduated... kinda.
Nice animations and game! Quitting a game works but if I want to undo, the circle comes but after that (before the undo steps follow) game crashes with black screen. Tried different levels and only if you ,,do" the undo (before is fine).
#29
As it happens, I have just totally revamped the UNDO system and it appears to be functional - I guess the prior version was buggier than I thought!  I took the opportunity to add a bit of audio while it's in action, and also fix various animations. It's not perfect, but it's way better!
Edit: video does not have audio!  I've also made a few changes post-video - the undo circle now briefly highlights a moved box AFTER it is moved; this makes the flow a bit more visually sensible. Also I fixed up the ending sequence to show a bit of background fizzle just before showing the stats screens. Also also I changed the scoreline to show the #moves (left) and #pushes (right).
BTW the stats screens are just placeholders - I'll work on making those pretty sometime soon.
