Download latest here!
I rewrote the UNDO system - whereas previously it held the last 100 *moves*, now it holds the last 100 *box pushes*.  I also spent some time working on the visuals and controls. Now it's good.
I cleaned up the end of level quite a bit, so that's good too.
Pretty close now to installing a bunch of screens and calling it "complete". Maybe.
This version should not have any bugs. Fingers crossed.
Bugfix; move counter was incorrect if you tried pushing a box that couldn't move.
Tweaks; button to exit title screen
cleaner stats screen
Known bug statistics for room selection not updated if you early-abort end of room
That's it for today.
Bomberman94
Played the penultimate version and I must say great presentation and gameplay. Everything feels right and intuitive. More rooms (obviously) and a safekey feature that saves solved (grey marked) rooms and best (least moves) per room would be phenomenal - at least for me personally 😃
Here's the first official "release candidate". I have 31 screens installed; I'll reserve the option to have a paid binary with (say) 100 screens - thinking just a few $ to buy me a coffee. But the free version, anyway, will have a few dozen screens give or take.
In this version I'm unaware of any bugs; it seems pretty solid to me.
#34
A few minor bug-fixes.
I also put an enable/disable iCC on ALL the switches (left/right difficulty and TV colour). Toggle any of those at any time and the ICC mode will change. Game always boots up in iCC mode; if you flip the switch you toggle between iCC/ChronoColour.
Game looks OK in ChronoColour, so that's nice.
Bomberman94
Played your last version: can't find any problems - plays and feels right!
I finished different screens and they were marked grey - played again and better result was updated correctly. Terminated a screen (holding button to quit) and done some undos (partly or completely) and they worked fine. Great game - will play further and look if I'll find something but at the moment everything is beautiful.
#36
I did some refinement on the visuals; particularly the colours.
Rather than colours everywhere on the title screen, I've gone for a more subtle one-colour-scheme for the workman/player. He has a subdued work uniform.
On the actual game screen, though, I've made a few changes
* the colours are now random instead of selected from a set of 8.  May need refinement, but it does give the rooms less of a "same old, same old" feel.
* I have changed the border characters to a striped pattern; I rather like this
* I have more carefully tied the player movement with box pushing, so they are more in synch
* I have discarded the room ID concept; we now just have room numbers
In this version there are 56 rooms.
Bomberman94
#37
Played last version:
- there's a screen jump from 50 -> 51 and 52 -> 51 (having 56 rooms is very great btw!)
- great choice of colors for the man, I like it a lot
- good idea to get rid of the ID numbers (because no need/added value for the player)
- I like random colors for the screens (how many combinations are possible?)
- to be honest I don't like the striped pattern outside the maze - does not fit the style (a single color or ,,some kind of grainy" pattern would be fine (maybe a solid dark or light color?)
- color scheme changes within one room (please look at top of the screenshot) not sure if intended
- I liked the evaluation after solving a room - actually there is only ,,GOOD" if done perfect (?) but nothing if you just solved it (with too much moves or is there a rule for this?)
Here's a video of the most recent WIP.
Quote from: Bomberman94 on 18 Aug 2025, 12:27 AMPlayed last version:
Probably overtime. I might not have such complex screens, or I will split the screen unpack into multiple frames. However, before I do that I will be rewriting the packing scheme to improve compression.
Quote from: Bomberman94 on 18 Aug 2025, 12:27 AM- I like random colors for the screens (how many combinations are possible?)
Gazillions. 16x16x16, I think - that's 4K variations. Give or take.
Currently I don't prevent any 2 of the 3 colour combinations from being identical. So, it needs some work.
And some colour combinations look pretty awful.
Quote from: Bomberman94 on 18 Aug 2025, 12:27 AM- to be honest I don't like the striped pattern outside the maze - does not fit the style (a single color or ,,some kind of grainy" pattern would be fine (maybe a solid dark or light color?)
It grows on you.  The new version has taller characterset characters. 30 scanlines instead of 27. This in turn enabled me to even out the bricks in the normal view, but also make the stripes larger and even in size.  We shall see how it goes.
Quote from: Bomberman94 on 18 Aug 2025, 12:27 AM- color scheme changes within one room (please look at top of the screenshot) not sure if intended
Intended - a holdover of how the palette was generated in Boulder Dash and I simply never removed it. I think it's OK.
Quote from: Bomberman94 on 18 Aug 2025, 12:27 AM- I liked the evaluation after solving a room - actually there is only ,,GOOD" if done perfect (?) but nothing if you just solved it (with too much moves or is there a rule for this?)
I'm just trying to find a good balance for this. Because the database # of moves to solve is actually unreliable (I have solved moves quicker than database says), I first put "WOW" if you were doing it faster. And "GOOD" if you matched the database, and nothing if you were over.
Many changes as detailed in previous post/video.
* Palette mods - random level colour
* set palettes in room selection/title
* colour 'graduations' down room (subtle)
* char sizing increased to 30 deep (10 trixels)
* deadlock animation "?" character added
* vertical push animations for player
* reworked target animations
* revamped "locked" box animation
* new "?" frame to indicate deadlocked box (+ animation)
#40
I found/fixed a bug that's been in the engine since day 1; way before "Wen hop?".  So, occasionally there's been a single pixel below the toe of the player. Couldn't for the life of me figure it out, and it was sometimes there, sometimes not.
Today - decided to track it down. It turns out that in the title/menu screen, I set/use VDELP0/1 for the sprite grid. However, I neglected to clear this for gameplay -- the dot was caused by erroneous sprite delays. Strange it all "looked so good" with that happening. But anyway, now fixed and the player looks somehow "crisper"; in any case his feet are now more clearly defined and there's no longer that weird dot. Glad to get rid of that bug.
I put in a new colour option - if you press SELECT during gameplay, it will choose a new random palette for the room. Rather than try to limit to "nice colours" - I'll just let the system generate completely random colours and let the user change it if it's too awful.  Note that there are 3 colours in iCC/ChronoColour which are mixed to give the 8 "visible" colours. But as it happens, one of those changes colour vertically down the screen too - so there are 4 randoms each any of 16 hues.
I have played a bit with graphics once again- in particular giving the player a more visible hat (purple/pink this time). Red's obviously out, and blue didn't look great.  I also updated the box graphics.
50 rooms in this version.  Gonna call it "complete"... ?
Bomberman94
Played last binary - here're my thoughts:
Solid and the use of colors is a matter of taste (I have a deja vu 😁). But it's good to change a pattern if needed.
I would question the use of the mini view - it doesn't help much because you can hardly identify all objects and the mid view will do the trick except: room 42 (not centered in mid view), room 44 (nearly perfect centered in mid view) and room 47 (ok here the mid view won't work because room too big). I would center 42 and 44 and simply change 47 with another new room - not so ,,confusing" for the player or say: easier and faster to use.
Thatguy427
I've been playing this whenever I get the chance and I definitely enjoy it. I've only made it to map 11 so far. I also manly use the zoomed out screen. I do love the sunglasses when the level is complete. Great touch.
#43
Following my serendipitous discovery of a "flicker/shimmer-free" iCC mode when developing Gridlock, I have back-ported the changes to Sokoban and here it is...!
Bomberman94
Plays fine with new pCC mode - a great enhancement!
