Download latest here!
This version adds room selection on the menu at the start.
It also goes to the next level once you complete the current one (after a button press).
Counter (top left) now counts moves rather than box pushes.
On room completion, background will sparkle.
Star swipe now working properly
I'll place the binaries in this thread from now on.
Better title placeholder, cleanups.
#3
Extended "suicide" hold-button delay from 1/2 second to about 5 seconds.
Fixed screen garbage on startup in random memory mode.
Here's a very "clean" version - everthing working as I expect.
I played a bit with the graphics - not sure if that will remain.
About to embark on an "undo" system.
#5
Post-release of the GIT repository, I've been going through and removing lots of redundant code (mostly not-called).  I also added a couple of things that were already there but not necessarily used; and the serial number.  Press SELECT+RESET together to see the binary serial number on the room selection screen.
#6
The UNDO is now fully functional and I've found/fixed my crash bug. It was a memory overlap problem.
OK, controls...
Screen starts up in NORMAL view (big chunky characters/graphics).
If you press the button once, then it switches to MID view (around half the size).  In MID view the system attempts to center the room horizontally and/or vertically to minimise scrolling.  Some rooms are way-big, some are tiny.  MID view is fully playable. To return to NORMAL view, press the button once.
If you press the button twice rapidly (i.e., a double-click) from either of those views, then you go to OVERVIEW.  This is the "famous" one pixel display.  It's also playable. From that view, a single or double click will return you to NORMAL view.
The button is overloaded. If you HOLD IT DOWN, you will enter into a special UNDO mode. That puts "UNDO" on the scoreline and a number, indicating the number of recorded moves you can take-back.  Use this when you make a mistake, obviously.  Once in UNDO mode, each button press will do a "maximal" undo.  That is, it will backtrack the player moves until a box has been restored to an earlier position.  The move counter will decrement to show you how many "undo steps" are remaining. You can continue with your undo button presses. When there are none left, the screen will flash green and you're returned to normal gameplay.
Also, when you HOLD DOWN the button, you are returned to normal gameplay.
There's some rudimentary "deadlock" detection in there. That's where a box or boxes are in positions that make it impossible to complete the room. For example, a box in a wall corner that's not a target position-  cannot be moved. There are a few deadlock situations installed, and I hope to do more. Basically if the system finds a "deadlock" then it will overlay that word at the top of the screen to tell you. In that case, you CANNOT complete the room and you should use UNDO until the word "deadlock" goes away.
If you want to abandon a level, hold down the joystick button for "reqlly quite a while". Don't let go!  It will first go to UNDO mode, and then after a while flash "EXIT" and then return to the menu.
Bomberman94
Does it have automatic TV system detection or is this strictly NTSC at the moment?
#8
Quote from: Bomberman94 on 20 Jul 2025, 01:48 AM
It should have, but I think it's broken. Will review.
A minor update/reversion. The deadlock detection is/was a bit dodgy and it was claiming deadlock when it shouldn't. I've loosened the checks for now, until I can fix that.
Found/fixed the console-type autodetect. SHould be working for everything now.
Funny and interesting SNAFU.  The autodetect is in the copyright screen code. Because I dumped the copyright, the easiest way was to only show it (black screen) for a couple of frames. But the autodetect code was set to wait 10 frames for precise calculation. So it never ran.  The copyright short-circuit, so to speak, ended everything too early.  So, now working.
I also rewrote the deadlock detection code. It now appears to be working correctly, and detects a number of simple cases properly.
See post(s) below for full details of how to use the button to perform various functions
a) switch to mid-view
b) switch to overview
c) switch back to normal view
d) trigger UNDO mode
e) perform a single box-move undo
f) exit UNDO mode
g) exit the current room
A bit of eye candy - particle system activates when you lock a box on its target.
Meanwhile, various little improvements. I will start work on room compression now.
YOU MUST BE A FORUM MEMBER TO SEE/DOWNLOAD BINARIES HERE.
#13
Some nice eye candy -- snail's trail now working well.
Here's 16 rooms of playable goodness.
I reworked the UNDO just a little bit.  When you hold down the fire button it enters undo mode, and the player wiggles a bit. From then on, button presses will undo the moves.  An undo will continue automatically until a box is moved, so you see the player "zooming around" on the room when you press the button. Undo also exits when there are no undo moves left, OR when you use the joystick.
I'm keeping the "snail trail/breadcrumbs". I like it. I did change to a less in-your-face colour as suggested.
